I don’t see Pause/Cancel/Resume macros in my printer.cfg file in the Macros section of the Dashboard, not sure how to control which macros appear there. They also do not appear in the Macros tab in Settings. Other macros do appear, so not sure why some won’t. Example below of a couple that aren’t showing up…these are in my printer.cfg file.
I’m thinking that it may be due to the “rename_existing” option called in them, but not sure why that would keep the macro from showing up in my Dashboard or Macro settings. Appreciate any help regarding the rules of the road, what I should or should not do if I want a macro to appear in Dashboard and Macro settings.
Thanks!
[gcode_macro PAUSE]
rename_existing: BASE_PAUSE
{% set X = params.X|default(220)|int %}
{% set Y = params.Y|default(220)|int %}
{% set Z = params.Z|default(10)|int %}
{% set E = params.E|default(1)|int %}
SAVE_GCODE_STATE NAME=PAUSE_state
BASE_PAUSE
G91
G1 E-{E} F2100
G1 Z{Z}
G90
G1 X{X} Y{Y} F6000
[gcode_macro RESUME]
rename_existing: BASE_RESUME
G91
G1 E{E} F2100
G90
RESTORE_GCODE_STATE NAME=PAUSE_state MOVE=1
BASE_RESUME
RESUME_BASE {get_params}
I’d appreciate some clarification on why they don’t appear.
