Hello - Were attempting to read the thermistors of our nozzle using the big tree Octopus Pro (built-in Max31865) but we keep getting values significantly different or thermocouple errors when trying to enable the sensor type and configure the settings - Weve tried in Marlin and klipper and keep getting the same thermocouple error - Pronter Face says its a min temp error before shutting down the board. is there any example code or solution anyone knows? We’ve clicked and tried every example - See attached Klippy Log
klippy (10).log (476.1 KB)
Extruder and bed are way out of line. I assume it’s no -43°C at your place.
... heater_bed: target=0 temp=-46.4 ...
And when Marlin also gives errors, you may check the wiring.
