Printer Model: Heavily modified Wanhao I3
MCU / Printerboard: SKR 1.4
oor.txt (808.0 KB)
I am experiencing a very puzzling issue… I set up klipper for the first time 1-2 weeks ago and I already printed 1kg of filament, so I’d say that everything works nicely except for:
Power on printer
Start Print
Finish print
Start second print
Printer starts with the normal preprint routine: home, z-tilt, bed level, custom wipe&purge macro
The next move would be to start printing but here I always get the same “move out of range” error
Restart firmware
Start Print - all good
I have attached a trimmed log for your convenience. You can ctrl+f for “start first print” and “start second print”.
I would really appreciate your help!
Hello @aerielpally !
Is that the genuine klippy.log?
For the future: Please always attach complete and unmodified logs.
As to your issue:
- Likely caused by the line
G1 Y{Y_MAX} Z{Z_MAX/4.0} F6000
- You need to make sure to be in absolute positioning mode when using this command
- Try putting a
G90 before this line
Haha I thought it makes life easier for anyone who is willing to help if I crop the log to parts that matter but next time I will post the full log!
Thank you very much - adding G90 helped and I am now printing the 3rd print without issues!
Haha, oh no… now, after the 3rd print or so I got “Extrude only move too long (-3892.157mm vs 160.000mm)”
Would you mind to check my start gcode again? I guess it has to do with the purge step right at the end of the macro but I still have too little understanding for gcode stuff.
Thats the part of the macro I guess is to blame:
## Wipe nozzle
{% for wipes in range(1, (wipe_qty + 1)) %}
G1 X{start_x + wipe_dist} F{wipe_spd * 60}
G1 X{start_x} F{wipe_spd * 60}
{% endfor %}
G1 X90 Y-25 F6000
G1 Z2 F600
G1 E20 F70
G1 X90 Y0 F1000
For me, it has proven good practice to reset the extruder with G92 E0 on the following conditions:
- Shortly before a print starts, e.g. as one of the last commands in PRINT_START
- Before and after manipulating the extruder in any way, e.g. purge, wipes etc.
- On error conditions
This will make sure that no strange values keep adding up until an error is created.
Thank you very much, I think I understand now!
