Hello. I’ve encountered an issue after using pause and resume. When the printer returns to the print position and resumes printing, for some reason, the nozzle ends up slightly higher than the model, causing the layer to be deposited in the air, which leads to the entire model failing. Thanks for your help! klippy (2).log (2.0 MB)
Is it possible to replace this macro with another one? That is, simply create a new macro with the same name as the old one. I have my own macro in the macro file, but it works just as poorly. Where can I get a normal pause and resume macro?
