What is your point? Can you please explain that more detailed?
is there a way to connect octopus pro to linux based old desktop motherboard via different communication port than usbc? i was trying to change settings in firmware build, yet with no success.
You might post a picture âand USBC port unsoldered from the boardâ.
USB-C on the Octopus, USB-A on the RPi. Ethernet on your old desktop motherboard, Ethernet on the RPi.
I guess your problem is this BIGTREETECH Octopus Pro STM32F429 | RatOS
I donât really get your problem!
If I donât understand you, please explain your problem more detailed.
Good luck, hcet14
You can use an USB to TTL adapter
- The USB side goes into your mainboard
- The TTL side on your printer board
See Connect SKR 1.4 Turbo and RPi3 using RX, TX, GND (UART) ¡ Issue #2913 ¡ Klipper3d/klipper ¡ GitHub to get an idea what is involved
Can I ask what is your âold desktop motherboardâ?
USB A or USB C connectors shouldnât be part of the discussion - youâre going to communicate with the controller board with the CDC protocol (which goes back to USB 1.0) so it doesnât matter what connector youâre using.
Iâm asking because I feel like thereâs something more here.
