highly modified E5+
BTT octopus pro
This is the continuing saga of WOWElectronics which I thought was in configs but cannot now find that thread.
I might add that this discussion actually started about a year ago, on a tronxy400 with the same problem that was not solve, then continued some time later with another copy of the same octopus pro board in a 2 trees sapphire 5, also ending w/o a solution.
Symptoms seem to be that if the driver0 and driver1 sockets are all 4 jumpered 2-3, then neither spi nor uart works. The question is why?
those 2 driver sockets have signal stealers fitted, and they are driving the opto coupled inputs of a pair of hanpose cl42 or cl57 drivers mounted of the frames close to the motors they control, and stepper_buzz stepper=stepper_x (or stepper_y) works as expected.
But, it cannot talk uart to tmc2209’s and it can’t talk spi to tmc5160’s.
So this is not a new problem, this is the third such failure in a row. with zero successes.
I have found on the last couple pages of Config_Reference.md,
a section of stuff on the spi buss that I don’t have in my .cfg file.
I reformatted that doc to contain the loooooong lines and printed it which added a page to its printed length. Heading of that section:
Common SPI settings.
The first item, unk to me, is:
#spi_speed: and it does not list a default, altho I recall reading some place that linux could do this at 400000 hz. next item is
#spi_bus: and has a lengthy explanation but no default value.
And I no clue where to find that info.
Now back to around page 96, under tmc5160 are several more entry’s I don’t have and ndi where to find them.
That listing also shows the above 2 config entries but has more:
#chain_position: does this have a base0 start, and does it start this chain at driver socket 2 from base0 where the first tmc5160 lives? or what? This looks important.
#chain length: which I assume would be 3 since there are three of the tmc5160’s in this Octopus pro ? next is
#hold_current: which I can define as a reduction from run current.
Then there is another 2 pages of stuff for the tmc5160!
You can even remap the motors microstep mapping.
Thanks for any info/insight.
Thunderbird has helpfully deleted my last msg from BTT’s tech guy, and BTT hasn’t “answered” the phone in about 2 weeks now… So I need someone who has made uart or spi actually work on an octopus pro. What do you have in your printer.cfg that I don’t have in mine, or is this a known bug in octopus pro’s. IDK.
