Offset printer head to bed
  • This printer comes with a modified and non-standard Klipper. Likely only Creality knows what they have done.
  • It should work out of the box as it is set up by Creality.
Before you start messing with it and potentially making things worse, you should check if there is a different root cause and consult Creality.
More on this here: 3D Printers with Preinstalled and Modified Klipper Versions
