I’m printing a model with wipe tower, when it finished last move over the model, the next command is moving to wipe tower, at this time, I paused it, then resume it, it moved to the last position where it paused, but how to run next moving command instead moving to the last position
AFAIK, this is not possible.
When pausing, Klipper records the last position and this is where it returns.
Klipper just reads a stream of gcode and passes it on to be processed. When paused, it picks up where it has been stopped since no other information is available.
Theoretically, the next gcode command could be a fan speed change or temperature change, so how should Klipper know what you would like?
