Already tried:
Restarting klypper
Restarting octopy
Restarting the raspberry
Power off the plug where everything is connected
And still nothing
Already tried:
Restarting klypper
Restarting octopy
And still nothing
This is really strange and the log file is atypical. Try flashing the board again:
cd ~/klippermake distcleanmake menuconfig β Choos the appropriate parametersmakemake flash FLASH_DEVICE=... β Acc to your board or copy to SD and rebootStill nothing β¦ Here is the new Log
klippy.log (46.2 KB)
On contrary, the log is significantly different:
Starting heater checks for heater_bed
Starting heater checks for extruder
Stats 336192.1: gcodein=74 mcu: mcu_awake=0.002 mcu_task_avg=0.000009 mcu_task_stddev=0.000008 bytes_write=5791 bytes_read=7575 bytes_retransmit=9 bytes_invalid=0 send_seq=283 receive_seq=283 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71998121 heater_bed: target=0 temp=19.3 pwm=0.000 sysload=0.00 cputime=1.563 memavail=1564756 print_time=333.644 buffer_time=0.000 print_stall=0 extruder: target=0 temp=19.6 pwm=0.000
Stats 336193.1: gcodein=74 mcu: mcu_awake=0.002 mcu_task_avg=0.000009 mcu_task_stddev=0.000008 bytes_write=5841 bytes_read=7732 bytes_retransmit=9 bytes_invalid=0 send_seq=287 receive_seq=287 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71998102 heater_bed: target=0 temp=19.2 pwm=0.000 sysload=0.00 cputime=1.586 memavail=1564756 print_time=333.644 buffer_time=0.000 print_stall=0 extruder: target=0 temp=19.6 pwm=0.000
Stats 336194.1: gcodein=74 mcu: mcu_awake=0.002 mcu_task_avg=0.000009 mcu_task_stddev=0.000008 bytes_write=6654 bytes_read=8431 bytes_retransmit=9 bytes_invalid=0 send_seq=327 receive_seq=327 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71998065 heater_bed: target=0 temp=19.1 pwm=0.000 sysload=0.00 cputime=1.650 memavail=1564756 print_time=334.291 buffer_time=0.000 print_stall=0 extruder: target=0 temp=19.7 pwm=0.000
Stats 336195.1: gcodein=74 mcu: mcu_awake=0.002 mcu_task_avg=0.000009 mcu_task_stddev=0.000008 bytes_write=7701 bytes_read=9363 bytes_retransmit=9 bytes_invalid=0 send_seq=383 receive_seq=383 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71998121 heater_bed: target=0 temp=19.2 pwm=0.000 sysload=0.00 cputime=1.735 memavail=1564768 print_time=335.273 buffer_time=0.000 print_stall=0 extruder: target=0 temp=19.5 pwm=0.000
Now the log contains the Klipper typical status messages that were completely missing in the previous logs.
But it also contains in line 308:
Unknown command:"PRINT"
How are you trying to start the printing process? Do you have this PRINT command in your slicer start code?
This message was just a test to see if there was a ββ print ββ command
I use to start print by the ββ print ββ button on octoprint
Can you please share the systeminfo bundle of OctoPrint?
octoprint-systeminfo-20230116200841.zip (15.2 KB)
Here it is
It seems, the SpoolManager database is corrupted.
Try running without all 3rd party plugins except OctoKlipper.
That was it ! Wow what a mess for that β¦
Thank you so much for the help !
