Provok3d Therm^2 Firmware to overflow rom
Printer Model:
MCU / Printerboard:
Therm^2 Board
Klipper flashing STMF042
Building out/compile_time_request.o
Version: v0.12.0-482-g2ec69ae36
Preprocessing out/src/generic/armcm_link.ld
Linking out/klipper.elf
/usr/lib/gcc/arm-none-eabi/12.2.1/../../../arm-none-eabi/bin/ld: out/klipper.elf section .text' will not fit in region rom’
/usr/lib/gcc/arm-none-eabi/12.2.1/../../../arm-none-eabi/bin/ld: region `rom’ overflowed by 5089 bytes
collect2: error: ld returned 1 exit status
make: *** [Makefile:73: out/klipper.elf] Error 1
Can somebody help me please
It seems the resulting firmware image is too big for the used MCU. Try:
Thats the standard
Umm, yes, I know. What do you want to say with this? Try with the config given above.
with your setting it works
Thanks for help
