That did the trick, klipper-repl is now installed in ~/klippy-env/bin:
Now, I don’t have a link to the Klipper API (or Klipper itself) in the run folder:
This is important because when I try to run klipper-repl with /run/klipper/api as suggested in the klipper-repl GitHub page, I get:
Reading through the klipper-repl Discourse announcement:
I tried using printer_data/comms/klippy.sock (which is used there but got the same error as the last post in the thread):
Now, I did try restarting the Klipper API (I know I shouldn’t have bothered, but I had to try) using the command:
~/klippy-env/bin/python ~/klipper/klippy/klippy.py ~/printer_data/config/printer.cfg -a /tmp/klippy_uds -l /tmp/klippy.log`
This is from the Klipper API page:
I changed the printer.cfg location to match what was in the system.
I’m guessing I’m not providing the correct link to the Klipper API Socket, but I have no idea where it is.
Any ideas for next steps?
Thanx.
