Pi 3B+ & RP2040-Zero
After failing to get my MPU6050 working I’m now trying to connect an ADXL345 via a RP2040-Zero by following instructions here : Raspberry Pi Pico + ADXL345: Portable resonance measurement
However, the RP2040 is never recognised by the pi, ls -l /dev/serial/by-id/ or by-path , only sees the single connection which is the printer board and if i disconnect that none are seen. I’ve tried several cables, the RP2040 works fine with pc, appears as removable storage, recognises and self-flashes uf2 files including a blinking led demo I used as a test, & appears to load klipper.uf2 ok from pc (compiled on pi and copied over via winscp), but the pi never sees it. Voltage at the rp2040 is OK, & I’ve tried booting the pi before & after usb connection.
my .cfg would contain this if i could get the rp2040 id …
#[mcu RP2040]
#baud: 115200
#restart_method: command
Obtain definition by “ls -l /dev/serial/by-id/”
#serial: /dev/serial/by-id/usb-Klipper_rp2040_E66138935F154C28-if00
#[adxl345]
#cs_pin: RP2040:gpio1
#spi_bus: spi0a
klippy (33).log (104.3 KB)
I was able to do
sudo mount /dev/sda1 /mnt
sudo cp out/klipper.uf2 /mnt
sudo umount /mnt
one time, and when mounted I could see the address (/dev/serial/by-id/usb-Klipper_rp2040_E6626005A7478E2F-if00) but on reconnection/reboot it fails to connect, nothing appears under /dev/ or any /dev/sda …
Has anyone else experienced this or have any ideas what’s wrong ?
