Run macro from macro?
Printer Model: Ratrig Vcore 3.1
MCU / Printerboard: Octopus Pror
Not necessaty
First of all, greetings and maybe in some countries it will be soon, but congratulate you on the new year in advance…
Can you run another macro in a Klipper macro?
If yes, how would it be done?
The answer is clear… Why do you want to do that? Simply copy the second macro, into the first…
I would be interested in doing it this way, for ease of editing, since this “secondary” macro would contain a position that would change over time, and for simplicity, convenience, mine, I would only have to modify the coordinates in the secondary macro…
Yes you can.
Here an example from my printer.cfg
[output_pin LIGHT_pin]
pin: PE3
pwm: False
value: 0
[gcode_macro M355]
  {% set S = params.S|default(1)|int %}
  #default_parameter_S=1
  SET_PIN PIN=LIGHT_pin VALUE={S}
