Printer Model: Ender3v2 and Ender 3v3 SE
MCU / Printerboard: BTT Pad
Host / SBC- Mainsail
Running ls /dev/serial/by-path/* to see what USB are plugged in and assign them to each printer. however, regardless of what port I assign them after reboot, only one printer connects. sometimes its the v2, other times it’s the SE. I can’t find a rhyme or reason for it.
v2log.log (903.9 KB)
SElog.log (901.1 KB)
Are you sure the printer have different serials?
I assumed so, however, admittedly not sure. How would I check that. When I run by ID I get this
biqu@BTT-Pad7:~$ ls /dev/serial/by-id/* /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
only 1 response shows up.
Have you tried to get the id by just connecting one printer when running ls... and then the other one?
I unplugged, rebooted and ran the ls, then repeated with the other printer on a different USB, however, I ended with the same result
Then you won’t be able to run them both with two Klipper instances on one SBC.
No instance can know to what printer it should connect.
Am I not able to identify them by-path instead, and assign them accordingly?
They also will have the same id by-path
When I run by path I get to entrys
biqu@BTT-Pad7:~$ ls /dev/serial/by-path/* /dev/serial/by-path/platform-5200000.usb-usb-0:1.2:1.0-port0 /dev/serial/by-path/platform-5200000.usb-usb-0:1.3:1.0-port0
If I unplug one and run it again it only shows 1 knowing one was unplugged.
Sorry, maybe I’m being dense here…
I have it configured in my printer.cfg as
[mcu] serial: /dev/serial/by-path/platform-5200000.usb-usb-0:1.2:1.0-port0 restart_method: command
In the documents they mentioned flashing the micro controller with something like this
sudo service klipper stop make flash FLASH_DEVICE=/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 sudo service klipper start
Should I run
sudo service klipper stop make flash **/dev/serial/by-path/platform-5200000.usb-usb-0:1.2:1.0-port0**=**/dev/serial/by-path/platform-5200000.usb-usb-0:1.2:1.0-port0** sudo service klipper start
I’m unsure what the printer’s unique serial port name would be.
Everything here is correct. My issue was there was another [mcu] section in my printer.cfg I did not see, causing issues. Once I deleted it worked like a charm
