Printer Model: Anycubic Chiron Frame and Motors
MCU / Printerboard: BTT Pico and BTT HermitCrab Can
I was lucky enough to get my hands on a hexacore Radxa Zero 2 last week. I’ve been making the move to Armbian and really enjoying Radxa’s Zero line. The size is great and the boards tend to run cool. I modified my device tree to force the board into host mode and I was able to simplify my wiring to have a single usb C cable connecting the Pico and the Radxa Zero after bridging D16 on the Pico.
It seemed like everything was working well running some homing commands and heating the hot end, but when I tried to run a print, I was getting MCU shutdowns. I did some review of klippy.log and found that my can bus queue was out of room. (I use the BTT Pico as a can bus bridge to the HermitCrab and sometimes a BTT EBB42 when I’m using my rotary roller or doing resonance measurements on the bed.)
I use a pretty standard /etc/network/interfaces.d/can0 file. It’s straight off the Klipper can bus page save a larger queue length:
allow-hotplug can0
iface can0 can static
bitrate 1000000
up ifconfig $IFACE txqueuelen 1024
So I was surprised when my prints were failing due to no room in the queue.
I tried to run ifconfig but it is not present on a default Armbian install. I had also noticed its absence in a /var/log/syslog entry noting it wasn’t present, but the can bus was working in my tests moving the toolhead and issuing commands and monitoring thermals.
So I ran ip -details -statistic link show can0 and to my surprise my anticipated queue length of 1024 was being reported as just plain 10. I ultimately did an sudo apt install net-tools and rebooted, and everything is working now as expected.
This might be a batter question for an Armbian discussion, but am I doing it wrong? My understanding is that net-tools is being deprecated. Is there some other place that I should be setting my queue length? I looked through the settings for the can interface in nmtui, but I didn’t see an area there where I could set the queue length… Any thoughts or experiences anyone has on best practice regarding this issue would be much appreciated!
