Printer Model: Tronxy x5sa
MCU / Printerboard: chitu v6 (STM32F103)
Host / SBC: Ubuntu 22.04
klippy.log (flashsd.py related… no klippy(
I’ve got the Tronxy doing the flashsd using the software SPI, but I’m pretty keen on getting sdio working, since the hardware ‘should’ support it.
There even looks to be sdio code from Gregor Molter for the STM32 series (although only active for STM32F4 series in mainline).
Does anyone know if Gregor is still involved with Klipper anywhere?
Or has anyone played around with the sdio stuff at all?
Traceback within
File "/home/bevan/klipper/scripts/spi_flash/spi_flash.py", line 1674, in main
spiflash.run()
File "/home/bevan/klipper/scripts/spi_flash/spi_flash.py", line 1614, in run
self.run_reactor_task(self.run_sdcard_upload)
File "/home/bevan/klipper/scripts/spi_flash/spi_flash.py", line 1597, in run_reactor_task
k_reactor.run()
File "/home/bevan/klipper/klippy/reactor.py", line 292, in run
g_next.switch()
File "/home/bevan/klipper/klippy/reactor.py", line 340, in _dispatch_loop
timeout = self._check_timers(eventtime, busy)
File "/home/bevan/klipper/klippy/reactor.py", line 158, in _check_timers
t.waketime = waketime = t.callback(eventtime)
File "/home/bevan/klipper/klippy/reactor.py", line 48, in invoke
res = self.callback(eventtime)
File "/home/bevan/klipper/scripts/spi_flash/spi_flash.py", line 1569, in run_sdcard_upload
self.mcu_conn.configure_mcu(printfunc=output_line)
File "/home/bevan/klipper/scripts/spi_flash/spi_flash.py", line 1383, in configure_mcu
self._configure_mcu_sdiobus(printfunc=printfunc)
File "/home/bevan/klipper/scripts/spi_flash/spi_flash.py", line 1376, in _configure_mcu_sdiobus
raise SPIFlashError(
SPIFlashError: Failed to Initialize SD Card. Is it inserted?
The hardware schematic shows SDIO connected, and these are the pins that are working for software SPI. Plus Marlin has it setup for the Tronxy configuration.
x5sa-main_board.pdf (134.9 KB)
