This message after updateMCU 'mcu' has deprecated code (it is missing feature 'STEPPER_STEP_BOTH_EDGE')
Printer Model: Creality CR10MAX
MCU / Printerboard: CR10MAX original/
Host / SBC Raspberrypi
After last update, i received this message.
Klipper avertissements.
  • MCU ‘mcu’ has deprecated code (it is missing feature ‘STEPPER_STEP_BOTH_EDGE’). Recompiling and flashing is recommended (MCU version ‘dgus-reloaded-220828-0-g9687b278’, host version ‘v0.13.0-554-g60b6271c9’).
    klippy.zip (23.1 KB)
Hi @diltech ,
The solution is in the error message. You should recompile and flash Klipper firmware to your MCU board to make sure it’s compatible with the latest Klippy host software.
Thank you, yes, fix it !
