Quite a bit strange.
Referring to the data sheet and the first column in your first screenshot it says the register only allows write access.
However other registers with the same W flag are listed in your last screenshot…
If the bit shifting or other things are wrong it still should give some results I guess if it is intended to have results in a query.
