YES IT IS
ill use that from now.
YES IT IS
Can you please post your whole LOOP_TEST macro in one code block as Preformatted text?
I just re-ran it to confirm the behavior
[gcode_macro LOOP_TEST]
{% for step in range(1) %}
Z_DEC
M118 {zpos}
G91
G1 Z+3.0
G90
G4 P3000
{% endfor %}
gives
Error loading template ‘LOOP_TEST’: jinja2.exceptions.TemplateSyntaxError: Unexpected end of template. Jinja was looking for the following tags: ‘endfor’ or ‘else’. The innermost block that needs to be closed is ‘for’.
If i comment the jinja expressions it runs without error
#{% for step in range(1) %}
Z_DEC
M118 {zpos}
G91
G1 Z+3.0
G90
G4 P3000
#{% endfor %}
for compleatness this is Z_DEC
[gcode_macro Z_DEC]
varaible_zpos=0
G91
{% set num = params.NUM|default(1)|int %}
{% if num <= 100 %}
G4 P100
QUERY_BUTTON BUTTON=zswitch
{% if printer["gcode_button zswitch"].state == 'PRESSED' %}
{% set num = 100 %}
{% else %}
G1 Z-0.05
#M118 {printer.toolhead.position.z}
Z_DEC NUM={num+1} # Count u
{% else %}
RESPOND MSG="Done Decrementing Z"
{% set zpos = update("zpos", printer.toolhead.position.z) %}
G90
Can you unindent the {% endfor %} line so it is at the same indentation level as the {% for block?
{% for step in range(2) %}
Z_DEC
M118 {zpos}
G91
G1 Z+3.0
G90
G4 P3000
{% endfor %}
this code generates
You can’t have the two-line space in a loop or if statement. DynamicMacros splits the macros across the two-line spaces. Your macro is being run as two macros:
Z_DEC
and
M118 {zpos}
G91
G1 Z+3.0
G90
G4 P3000
{% endfor %}
Also, the zpos variable doesn’t exist in the LOOP_TEST macro. This macro should work:
Z_DEC
REPORT_Z
G91
G1 Z+3.0
G90
G4 P3000
{% endfor %}
[gcode_macro REPORT_Z]
Also, the update function doesn’t transfer variables between macros. It only transfers variables across the two-line spaces.
Thanks ! ill give it a bash
Hi
Seems you are trying to solve similar task which was already solved.
Take a look here: Secondary needle calibration
Maybe you can adapt it to your needs.
