As per previous posts, I am trying to build a MMU. With 5 extruder steppers and a bunch of switches to detect filament position. The coding/scripting proving to be much more difficult than anticipated.
I would like to use a Gcode button to monitor a switch and then use one of the extruder motors to push or retract filament to change the switch state and stop when it has.
I’ve recently started to get to grips with how klipper evaluates macros and I’m now starting to think that it might not be possible without advanced programming skills.
My current understanding is thus:
If I were to call a macro it has access to variable values at the time the macro is called. It cannot see any changes to the variables that exist outside of the macros being evaluated until it is called again.
I have a horrible feeling that if I call another macro from within the original macro. It for the most part has access to the same variable values that the original macro has. Thus I won’t be able change behaviour
Is my understanding correct? Any ideas how I could overcome it?
All I want to do I think is:
-Move filament 10mm
-check button variable
-move filament 10mm
… And so on until the variable changes
Unfortunately they weren’t successful in their efforts and pretty much confirms my suspicions that the entire macro chain is evaluated when the first macro is called.
I think I can still make my MMU work by using filament switches as the macro essential calls itself. Although I won’t be able to do anything clever when loading/unloading filament. It will just have to be loading/unloading set amount of filament and at the end of the macro when It returns to normal G code running. It will trigger a pause if something has gone wrong.
I would have liked to have tried loading filament again etc.
Looking at it, I would have to write a python script with the functions I want and call those functions using Jinga. Ive realised I was pretty naive about all this at the start of the project.
Is there any documentation on how you achieve and how that links back into the printer.cfg file. For some bed time reading?
In another thread I see you have implemented a MMU much like I want to.
How did you go about doing it? Is it much like I have described above?
I will be using 5 extruders. Basically your classic creality style duel driven roller extruders. I was planning on having a servo driven cam shaft that drives a dowel down on the extruder lever. So that once the filament is loaded and in the gears of the tool head extruder it can then freewheel essentially? Do you think that this is required? I am concerned about tension building up in the Bowden if I do not implement a free wheel system.
I have 6 stepper motors, each configured in a typical bowden setup, except these 6 “feeders” all feed into a 6-in-1-out “splitter,” which feeds into a direct-drive setup at the hotend. Each of the feeders is a Klipper “extruder stepper” and the direct-drive extruder is the “extruder.” Before starting a print I manually load the filament spools I want to use so that the tip of each filament is just to the mouth of the splitter (what I’ll call the “rest position”).
I’ve got custom load and unload macros that sync the appropriate extruder_stepper to the extruder motion queue and then either extrude or retract the filament the specific distance I measured between the rest position and the nozzle side of the heatbreak. (The unload does some tip-shaping moves first.)
While printing, both the “feeder” stepper and the direct-drive stepper are operating on the filament at the same time. This is actually a great setup because I can significantly reduce the tension on both extruders and reduce the run current (thereby letting the motors run cooler), as they’re both working together. This has eliminated the problems I used to have with the spur gears “biting” into the filament or rolling it into an oval shape with frequent retractions, while at the same time eliminating skipped steps and under extrusion.
My setup does not have any type of filament homing or detection. I just manually load each spool so that the tip of the filament is in the “rest area,” and as long as I use the load and unload filament macros, the filament tips are always returned to the rest area and ready to go the next time that filament is called for. I’ve been running this setup for more than 4 years now and haven’t had any problems that filament sensors or homing would have helped.
Thank you for sharing that, I will probably give the freewheeling camshaft a rain check. Gives me confidence to proceed. I have been hovering on buying/building ercf. But they seem to be very sensitive to filament friction which put me off.
Would you mind sharing your macros it would undoubtedly save me a lot of time
Sorry for the delay, but the reason it’s taken me so long is that my macros are an unholy mess not fit for public consumption, mainly because they include a bunch of bells and whistles that are mostly specific to my setup. I’ll paste some of them below with this important caveat:
DO NOT USE THESE MACROS AS-IS! They will NOT work!
If you’re comfortable in Python and Jinja2, you should be able to read through them and see generally what the logic flow is, and maybe there are some aspects you can borrow from that would be helpful. And I’m happy to answer any questions you might have about them.
[gcode_macro GLOBALS]
variable_active_slot:None
variable_bowden_length:490
variable_hotend_length:80
variable_park_x_pos:249
variable_park_y_pos:120
variable_cooling_amount:0
variable_ramming_distance:9.5
variable_ramming_speed:2000
variable_pressure_advance:0.03
variable_display_group:"_default_16x4"
variable_filament_id:None
variable_filament_temp:None
variable_filament_type:None
variable_filament_color_hex:None
variable_nozzle_prime_distance:15
variable_retract_length:0.6
variable_z_hop:0.4
variable_tip_shape_distance:26
variable_secondary_purge_volume:0
variable_lightness_factor:0.05
variable_lightening_factor:0.05
variable_euclidean_factor:0.05
{% set globals = printer["gcode_macro GLOBALS"] %}
[gcode_macro FILAMENT_LOAD]
{% set last_filament = printer.save_variables.variables %}
{% set filament_db = last_filament.filament_db %}
; Don't pass EXTRUDER_STEPPER if calling this from another macro!
M400
{% if params.EXTRUDER_STEPPER %}
{% if printer["gcode_macro SYNC_EXTRUDER_MOTION"].stepper_synced is not none %}
{ action_raise_error('An EXTRUDER_STEPPER is already synced.') }
{% else %}
SYNC_EXTRUDER_MOTION EXTRUDER=extruder_stepper_{params.EXTRUDER_STEPPER|int} MOTION_QUEUE=extruder
SMART_HOME
{% else %}
; The calling macro should already have synced an extruder stepper.
{% if printer["gcode_macro SYNC_EXTRUDER_MOTION"].stepper_synced is none %}
{ action_raise_error('This will not work without a synced EXTRUDER_STEPPER.') }
{% if last_filament.filament_loaded %}
{ action_raise_error('Filament is already loaded!') }
; Don't pass PRINT_TEMP if calling this from another macro!
{% if params.PRINT_TEMP %}
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_id VALUE='"Manually Loaded Filament"'
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_temp VALUE={params.PRINT_TEMP}
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_type VALUE=None
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_color_hex VALUE=None
{% else %}
{% if "globals.filament_id" not in filament_db %}
{% set db_values = {'temp': globals.filament_temp,
'type': globals.filament_type,
'color_hex': globals.filament_color_hex} %}
{% set dummy = filament_db.__setitem__('%s'|format(globals.filament_id), db_values) %}
{% else %}
{% set dummy = filament_db[globals.filament_id].__setitem__('temp', '%s'|format(globals.filament_temp)) %}
{% set dummy = filament_db[globals.filament_id].__setitem__('type', '%s'|format(globals.filament_type)) %}
{% set dummy = filament_db[globals.filament_id].__setitem__('color_hex', '%s'|format(globals.filament_color_hex)) %}
SAVE_VARIABLE VARIABLE=filament_db VALUE="{filament_db | pprint | replace("\n", "") | replace("\"", "\\\"")}"
{% set print_temp = params.PRINT_TEMP|default(globals.filament_temp) %}
{% if print_temp is none %}
{ action_raise_error('New filament temperature must be specified.') }
{% set purge_temp = [last_filament.filament_temp, print_temp]|max %}
M104 S{purge_temp}; Heat up hotend
G91; Relative Coordinates
G1 E25 F400; Medium insert
G1 E25 F600
G1 E25 F800
G1 E{(globals.bowden_length) - 75 } F10000
G1 E{(globals.hotend_length)} F10000
SAVE_VARIABLE VARIABLE=filament_loaded VALUE=True
SET_ACTIVE_SPOOL
{% if not params.SKIP_PURGE %}
{% set model_purge = params.MODEL_PURGE|default(0)|float %}
M109 S{purge_temp} ; Heat up hotend and wait
{% if not printer["gcode_macro SECONDARY_PURGE_TUNER"].tower_is_running %}
_CALCULATE_SECONDARY_PURGE ; Calculate secondary purge
M106 S256 ; Turn on fan (Comment out this line to make purge pellets)
G1 E{globals.nozzle_prime_distance/2} F70 ; Prime nozzle at purge temp
M104 S{print_temp} ; Start transitioning to print temp
_PERFORM_SECONDARY_PURGE PRINT_TEMP={print_temp}
M107 ;Cut the fan
M400
M109 S{print_temp}
M106 S256
{% if params.FIRST_LOAD %}
G90; Absolute Coordinates
G1 Z0 F420
G1 E{globals.nozzle_prime_distance/2} F50; purge more
STORE_FILAMENT_DATA
{% if not params.FIRST_LOAD %}
M106 S{ printer.fan.speed * 510}
{% else %}
M107 ;Cut the fan
WIPE_NOZZLE
M400
G92 E0; Zero Extruder
# Dummy argument block for Mainsail
{% set dummy = None if True else "
{% set dummy = params.PRINT_TEMP|default(None)|float %}
{% set dummy = params.EXTRUDER_STEPPER|default(None) %}
{% set dummy = params.SKIP_PURGE|default(True)|bool %}
{% set dummy = params.FIRST_LOAD|default(False)|bool %}
" %} # End argument block for Mainsail
[gcode_macro FILAMENT_UNLOAD]
{% if (printer.print_stats.state not in ['printing', 'paused']) and last_filament.filament_loaded %}
{% if (printer["gcode_macro SET_PSU"].value)|int == 0 %}
SET_PSU VALUE=1
M104 S{last_filament.filament_temp}
SMART_HOME
PARK_TOOLHEAD
M109 S{last_filament.filament_temp}
SYNC_EXTRUDER_MOTION EXTRUDER={last_filament.last_synced_extruder} MOTION_QUEUE=extruder
G1 E10 F70
{% else %}
G1 E-{globals.retract_length} F1500; Retract
PARK_TOOLHEAD
G1 E{globals.ramming_distance + globals.retract_length} F{globals.ramming_speed}
G1 E-{globals.ramming_distance} F3000
G1 E{globals.retract_length - globals.tip_shape_distance } F3000
G1 E12 F200
G1 E-12 F200
G1 E12 F255
G1 E-12 F255
G1 E{globals.tip_shape_distance} F2000 ;move stringy tip into melt zone
G1 E-{globals.tip_shape_distance} F4000 ;extract clean tip from melt zone
M400
CLEAR_ACTIVE_SPOOL
G1 E-{globals.hotend_length + globals.bowden_length - globals.tip_shape_distance} F4000
M400
SAVE_VARIABLE VARIABLE=filament_loaded VALUE=False
DESYNC_EXTRUDER_STEPPERS
[gcode_macro _CALCULATE_SECONDARY_PURGE]
variable_model_purge:0
{% if globals.filament_id == last_filament.filament_id %}
{ action_respond_info('Same filament detected. Skipping secondary purge...') }
{% set purge = 0 %}
{% elif last_filament.filament_color_hex is none %}
{ action_respond_info('Last filament has unknown color. Enforcing minimum 10mm secondary purge...') }
{% set purge = 10 %}
{% else %}
{% set color1_hex = last_filament.filament_color_hex %}
{% set color2_hex = globals.filament_color_hex %}
{% set c1 = [] %}
{% set c2 = [] %}
{% for i in range(0,6,2) %}
{% set dummy = c1.append(color1_hex[i:i+2]|int(base=16)) %}
{% set dummy = c2.append(color2_hex[i:i+2]|int(base=16)) %}
{% endfor %}
{% set lightnessX = globals.lightness_factor %}
{% if not lightnessX %}
# Calculate Euclidean distance
{% set sums = [] %}
{% for n in range(3) %}
{% set dummy = sums.append((c2[n] - c1[n])**2) %}
{% endfor %}
{% set euclidean_raw = (sums|sum())**(1/2) %}
# Calculate Euclidean distance multiplier
{% set lightnessX = (euclidean_raw/442)*globals.euclidean_factor %}
{% set lighteningX = globals.lightening_factor %}
# Purge = Base + ((C2[R]+C2[G]+C2[B]) * euclideanX) + ((C2[R]-C1[R]),0)|max)+((C2[G]-C1[G]),0)|max)+((C2[B]-C1[B]),0)|max)) * lighteningX
{% set purge = ((c2|sum) * lightnessX) + ((((c2[0]-c1[0]),0)|max) + (((c2[1]-c1[1]),0)|max) + (((c2[2]-c1[2]),0)|max)) * lighteningX %}
{% set model_purge = printer["gcode_macro _CALCULATE_SECONDARY_PURGE"].model_purge %}
{% if model_purge > 0 %}
{% set purge = [(purge - model_purge), 0]|max %}
{ action_respond_info('%smm will be purged into model. Pre-adjusting secondary purge to %smm.'|format(model_purge, purge))}
COLOR_LOG PURGE={purge}
{% if globals.filament_type != last_filament.filament_type %}
{ action_respond_info('Different filament type detected. Enforcing minimum 10mm secondary purge...') }
{% set purge = (purge,10)|max %}
{ action_respond_info('Purge volume calculated with lightening factor of %s and lightness factor of %s.'|format(lighteningX, lightnessX))}
{ action_respond_info('Setting final secondary purge volume to %smm...'|format(purge))}
SET_GCODE_VARIABLE MACRO=_PERFORM_SECONDARY_PURGE VARIABLE=secondary_purge_volume VALUE={purge}
[gcode_macro _PERFORM_SECONDARY_PURGE]
{% set secondary_purge_volume = printer["gcode_macro _PERFORM_SECONDARY_PURGE"].secondary_purge_volume %}
{% if secondary_purge_volume > 0 %}
G1 E{secondary_purge_volume/2} F70 ; Do half of secondary purge during temp transition
M109 S{params.PRINT_TEMP} ; Stabilize at print temperature
G1 E{secondary_purge_volume/2} F70 ; Do the other half of secondary purge
SET_GCODE_VARIABLE MACRO=_PERFORM_SECONDARY_PURGE VARIABLE=secondary_purge_volume VALUE=0
[gcode_macro PARK_TOOLHEAD]
{ action_respond_info('Parking print head...') }
G1 X{globals.park_x_pos} F9000 ; Move to bucket
{% if not printer.gcode_move.absolute_coordinates %}
[gcode_macro FILAMENT_CHANGE]
{% set spool_registry = printer.save_variables.variables.spool_registry %}
{% set x_pos = params.NEXT_X|default(printer.toolhead.position.x)|float %}
{% set y_pos = params.NEXT_Y|default(printer.toolhead.position.y)|float %}
{% set z_pos = params.NEXT_Z|default(printer.toolhead.position.z)|float %}
M400
M107; Cut the fan
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_id VALUE='"{params.FILAMENT_ID}"'
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_temp VALUE={params.NEXT_EXTRUDER_TEMP}
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_type VALUE='"{params.FILAMENT_TYPE}"'
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_color_hex VALUE='"{params.FILAMENT_COLOR_HEX}"'
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=retract_length VALUE={params.RETRACT_LENGTH}
SET_GCODE_VARIABLE MACRO=_CALCULATE_SECONDARY_PURGE VARIABLE=model_purge VALUE={params.MODEL_PURGE|default(0)|float}
FILAMENT_UNLOAD
M400
{% for slot in spool_registry %}
{% if spool_registry[slot]['name'] == params.FILAMENT_ID %}
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=active_slot VALUE={slot|int}
{% endfor %}
SELECT_EXTRUDER
RESTORE_DEFAULT_PA
G1 Z{globals.z_hop} F18000
FILAMENT_LOAD
G1 E-{globals.retract_length} F1500 ;Retract
G1 X{x_pos} Y{y_pos} Z{z_pos + globals.z_hop} F18000
[gcode_macro _CLEAR_FILAMENT_GLOBALS]
{ action_respond_info('Clearing filament globals...') }
{% for param in ['id', 'temp', 'type', 'color_hex'] %}
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=filament_{param} VALUE=None
{% endfor %}
[gcode_macro STORE_FILAMENT_DATA]
{ action_respond_info('Saving filament properties to disk...') }
{% if globals.filament_id is none %}
SAVE_VARIABLE VARIABLE=filament_id VALUE=None
{% else %}
SAVE_VARIABLE VARIABLE=filament_id VALUE='"{globals.filament_id}"'
{% if globals.filament_type is none %}
SAVE_VARIABLE VARIABLE=filament_type VALUE=None
{% else %}
SAVE_VARIABLE VARIABLE=filament_type VALUE='"{globals.filament_type}"'
{% if globals.filament_color_hex is none %}
SAVE_VARIABLE VARIABLE=filament_color_hex VALUE=None
{% else %}
SAVE_VARIABLE VARIABLE=filament_color_hex VALUE='"{globals.filament_color_hex}"'
SAVE_VARIABLE VARIABLE=filament_temp VALUE={globals.filament_temp}
SAVE_VARIABLE VARIABLE=last_synced_extruder VALUE='"{printer["gcode_macro SYNC_EXTRUDER_MOTION"].stepper_synced}"'
[gcode_macro PRINT_END]
M106 S0 ; turn off cooling fan
M140 S0 ; turn off bed
FILAMENT_UNLOAD
WIPE_NOZZLE
M220 S100 ;Reset speed override to 100%
M221 S100 ;Reset extrusion factor override to 100%
M104 S0 ; turn off extruder
G90
G1 Y200; Remove Print Position
M84 ; disable motors
SET_SKEW CLEAR=1
SET_GCODE_VARIABLE MACRO=SECONDARY_PURGE_TUNER VARIABLE=tower_is_running VALUE=False
[gcode_macro WIPE_NOZZLE]
M106 S256
G4 P1000
G1 X-15 F10000
G4 P1000
G1 X15 F10000
G1 X-15 F10000
G1 X15 F10000
{% if printer.gcode_move.absolute_coordinates %}
{% else %}
[gcode_macro RESTORE_DEFAULT_PA]
SET_PRESSURE_ADVANCE ADVANCE={(printer["gcode_macro GLOBALS"].pressure_advance)}
[gcode_macro SYNC_EXTRUDER_MOTION]
rename_existing: BASE_SYNC_EXTRUDER_MOTION
variable_stepper_synced: None
{% if params.MOTION_QUEUE == '' %}
SET_GCODE_VARIABLE MACRO=SYNC_EXTRUDER_MOTION VARIABLE=stepper_synced VALUE=None
{% else %}
SET_GCODE_VARIABLE MACRO=SYNC_EXTRUDER_MOTION VARIABLE=stepper_synced VALUE='"{params.EXTRUDER}"'
BASE_SYNC_EXTRUDER_MOTION {rawparams}
[gcode_macro SELECT_EXTRUDER]
{% if globals.active_slot is none %}
{ action_raise_error('Cannot activate extruder without an active slot.') }
{% set slot = (globals.active_slot|int - 1) %}
SYNC_EXTRUDER_MOTION EXTRUDER=extruder_stepper_{slot} MOTION_QUEUE=extruder
M400
SET_PRESSURE_ADVANCE ADVANCE={globals.pressure_advance}
SET_PRESSURE_ADVANCE EXTRUDER=extruder_stepper_{slot} ADVANCE={globals.pressure_advance}
[gcode_macro DESYNC_EXTRUDER_STEPPERS]
SET_GCODE_VARIABLE MACRO=GLOBALS VARIABLE=active_slot VALUE=None
{% for n in range(6) %}
SYNC_EXTRUDER_MOTION EXTRUDER=extruder_stepper_{n} MOTION_QUEUE=
{% endfor %}
[gcode_macro _CHECK_FOR_REQUESTED_FILAMENT]
{% set name = params.NAME %}
{% set filament_list = [] %}
{% set dummy = filament_list.append(spool_registry[slot]['name']) %}
{% endfor %}
{% if name in filament_list %}
{ action_respond_info('Requested filament "%s" found.'|format(name))}
{% else %}
{ action_raise_error('Load "%s" filament in a spool slot and try again!'|format(name)) }
[gcode_macro SET_ACTIVE_SPOOL]
{% if globals.active_slot is not none %}
{% set id = spool_registry["%s"|format(globals.active_slot)]['id'] %}
{action_call_remote_method(
"spoolman_set_active_spool",
spool_id=id
{% else %}
{action_respond_info("No slot selected. Could not set active spool.")}
[gcode_macro CLEAR_ACTIVE_SPOOL]
spool_id=None
I’m interested in how you implement that. When I first cobbled together my setup I was thinking of trying to include a filament cutter because I was having a really hard time forming the tips of retracted filament so as to prevent them from catching or jamming when trying to reload them later.
I eventually found the key was to start the retraction/cooling sequence by first forcing the filament quickly toward the nozzle and then quickly retracting it again to force out as much of the already softened plastic as possible without softening any more of it. This is reflected in the macros as the “ramming distance,” and I found 9.5mm to be a good value for this. That was at least 2 years ago and I haven’t had a single filament jam since then.
