hello [EDACerton]
nice that you are “still” here; I’m already testing STEP 32 and right away with your CFG… and the modified end stops…
danke schon mal dafür
Unfortunately does not work. If I only correct your x and y lines, it now prints “y” 25% too large. when I upload everything I get this message…–>
your CFG. is also structured completely differently… some “things” from my file are completely missing and the order of others is slightly different.
so have to try a little more…
Make certain that you’re including the Mainsail config file, etc. if you’re uploading that printer.cfg, it doesn’t include extra components like that
I copied everything from a file again, this error “The klippy host software is attempting to connect”.
comes now whenever I want to save it.
Just checking… did you check the serial port in the config?
