Printer Model: Voron 0
MCU / Printerboard: PiZero2 / SKR Pico (UART Connection)
klippy.log (1.7 MB)
I’ve updated klipper/mainsail/moonraker randomly throughout this printer’s life with no issues until now. I have not made any hardware changes at all. As of a couple days ago, I am seeing intermittent shutdowns and nothing is obvious on my mainsail terminal (no obvious CPU usage spikes, nothing out of the ordinary anywhere). I have attempted to view the log data (and generated graphs), but even after reading a thread on how to interpret the data, I am failing. IMy attached log should show a completed print, another print I started and failed (note that mere days ago, before the issues began, this exact same .gcode file printed perfectly fine). Additionally, just minutes ago, I started my standard heat soak routine and in the middle of it (just heats bed), I got a ‘timer too close’ error. There seems to be no obvious consistency as to when/why this shutdown occurs.
Is there something obvious in this log to a trained eye?
Thank you in advance.
