Ability to pass screw number to `SCREW_TILT_CALCULATE`
On a multiple bed setup, it would be nice if we could pass which screws to measure to SCREW_TILT_CALCULATE
I have following issue:
The printer is composed of 4 beds with 9 screws each. See table below to see how they’re numbered.
The reference is Bed 2 Screw 5. For it to work, I need to first measure the front two beds with the reference, and then the back two beds with a pause in between to move the adjustment sheets from the front to the back as I only have two of them. While the measurement is paused, the reference should not be lost, as I would need to move the sheet from bed 2 to one of the rear two beds and thus am not able to get the reference again.
The sheets are supplied with the printer and have a hole punched out where the screw is so that it can be adjusted (top mounted screws on sprints).
Beds are numbered as follows (for reference):
| 3 | 4 |
| 1 | 2 |
Screws are numbered as follows (for reference):
| 7 | 8 | 9 |
| 4 | 5 | 6 |
| 1 | 2 | 3 |
