Hi Brian,
yes I have seen your topic about its behavior with the PROBE_ACCURACY command.
Does it keep to have range 0.000000? That looks a bit strange to me. How does it work in practice, with Z_TILT for example?
splitting the bigger electronics case from the probe itself seems to be a nice idea, since it makes positioning of the probe much easier. How long is the cable? Would be quite nice if ‘nearby’ means apart from the head.
How long is the triggering distance? If I look at your setup, it might be about 10mm?
