About the kick_ start_time parameter of the fan object
Printer Model:
MCU / Printerboard:
Why does setting the kick_ start_time value improperly cause Timer to close too? I once tried setting it to 0.01 and the default 0.1, but when using slicing software to generate commands with frequent M106 S255 and M106 S0, it was easy to Timer too close. When I set the kick_ start_time value to 0.5, When the value is set relatively large. The Timer too close issue will be significantly improved. It won’t appear again.How should this parameter be set more reasonably?
