Got a timer too close error when printing for a long time
Printer Model: Custom coreXY
MCU / Printerboard:MKS SKIPR + USB Toolhead
klippy.log.zip (6.3 MB)
…Hello everyone,
I got a “MCU ‘Toolhead’ shutdown: Timer too close” error after about 25 hours of printing.I used a USB hub to connect the toolhead and a 480P webcam with 5fps.I don’t know if the webcam is causing the problem.
Im not very good into finding errors at the logs. Does anyone have a clue?
I did analyze your log …
From analysis I can tell that most probably it was Toolhead communication issues which start growing last 3 hours of your print, but I didn’t spot any relations with CPU load or temperatures - so most probably it’s your serial cable (USB) or something else.
Here are some analysis data which i did derive from your log.
Hour from klippy start Max MCU sysload Max Toolhead Temp Max Host Temp Max MCU Temp Sum of MCU Retrastit Instances Sum Toolhead Retransmit Instances
0 2,51 49,00 32,7 21,1 1 2
1 2,31 48,60 33,2 21,1 0 1
2 2,43 48,50 32,7 21 0 0
3 2,35 48,40 33,2 20,9 0 1
4 2,53 48,10 32,7 21 0 0
5 1,88 47,90 31,8 20,9 0 1
6 2,36 47,50 31,8 21,2 0 1
7 2,25 47,30 32,3 20,9 0 1
8 2,71 47,50 33,2 21,1 0 0
9 2,77 47,50 32,7 21,6 0 1
10 2,14 47,60 33,6 21,8 0 0
11 2,32 47,80 33,2 22,1 0 0
12 2,90 47,80 35 22,3 0 1
13 2,79 48,00 34,5 22,5 0 0
14 2,91 47,90 35 22,3 0 1
15 2,37 47,90 33,2 22,6 0 2
16 2,42 47,70 34,1 22,5 0 1
17 2,06 47,50 34,1 22,1 0 3
18 2,38 46,90 33,2 22,1 0 9
19 2,65 46,70 33,6 21,7 0 15
20 1,97 46,40 33,2 21,6 1 28
Total 2,91 49,00 35 22,6 2 68
Thank you very much. Your reply has solved my problem. I took apart the USB cable and found that the copper wire was about to break. The problem was solved when I replaced the cable
