Accelerometers query works but crashes on resonance test
Printer Model: Custom
MCU / Printerboard: Octopus Pro 1.1
Host / SBC: PC
My acclerometer suddenly stopped working. It’s reading just find when i do a query:
accelerometer values (x, y, z): -1776.494261, 7846.182985, -5439.278036
but as soon as a do a ‘TEST_RESONANCES AXIS=X’ command the system crashes:
'Internal error on command:“TEST_RESONANCES” ’
i’ve tried two different Accelerometers and two different MCUs running the Accelerometers, same error. Don’t understand what changed since i last used this. Even did the same thing on my other printer.
Any help would be greatly appericated.
klippy (5).log (1.8 MB)
solved my own issue…
forgot to uncomment out the probe points:
[resonance_tester]
accel_chip:adxl345
accel_per_hz: 50
probe_points:
   #200,200,20 # an example
fixed by changing it to:
[resonance_tester]
accel_chip:adxl345
accel_per_hz: 50
probe_points:
