After today update from v0.12.0-88 to v0.12.0-98, whatever value I give to M300 command, beeper sound ( pitch) is always the same.
Rolled back to v0.12.0-88, everything works fine.
Anybody else?
Anybody else?
Hello @DukeLander !
Do you think an attached klippy.log - as it was requested - can help to find the issue?
Actually no, because everything is working fine except beeper pitch, its always a same whatever frequency I give.
But if you think its gonna help, I can update back to newest version to take log file.
Some changes were recently merged that change how an output_pin works. Seeing a log will be necessary to determine how you have the beeper configured, and what might be causing the issue.
Understood. I will do it as soon I have little free time. Tnx
HI
I have the exact same situation.
This happened on 2 of my printer that I’ve updated/flashed recently.
One is a Fysetc Spider V3 Mainboard, with a Mini12864 from Fysetc
The other one is a Btt Manta M8P mainboard with a Mini12864 from Btt.
Each of those had a different song playing at the end of print since a while, then after the update it doesn’t work properly.
I’ve uploaded the log from the Btt one, since it’s smaller than the other one
klippy-10.log (4.0 MB)
Thanks
Found the issue…
After the recent update
[output_pin _BEEPER_pin]
pin = EXP1_1
pwm = True
value = 0
shutdown_value = 0
cycle_time = 0.001
now needs to be
[pwm_cycle_time _BEEPER_pin]
pin = EXP1_1
value = 0
shutdown_value = 0
cycle_time = 0.001
The change is it now needs to be pwm_cycle_time instead of output_pin
Thank you, I was having the exactly same issue after update few minutes ago.
This worked. Thank you for solution
