I tuned my input shaper using an ADXL345 and put in the recommended shaper settings and got this. Am I missing something or is this all input shaper is capable of?
That is not a good result…Not reflective of input shapers capability.
Did you mind the acceleration recommendation?
Not all such artifacts are attributable to ringing.
If you want to test the effect dedicatedly then follow Resonance Compensation - Klipper documentation
- Do the ringing test with disabled shaper to get a reference
- Repeat with your chosen recommendation
