Anycubic Kobra Plus -- Hotend and MCU fan always on
Printer Model: Anycubic Kobra Plus
MCU / Printerboard: Trigorilla_Pro_A_V1.0.4
[controller_fan controller_fan]
pin: PA14
heater: heater_bed
[heater_fan heater_fan]
pin: PA13
On my printer, the hotend and MCU fans both go to 100% as soon as the printer starts up, regardless of the commanded status. Anycubic publishes the Marlin config for the stock firmware, so I know that the pins are correct:
// Fans
#define FAN_PIN                             PB9     // model fan
#define FAN1_PIN                            PA13    // auto fan for E0
#define FAN2_PIN                            PA14    // controller fan
#define CONTROLLER_FAN_PIN                  FAN2_PIN
#define FAN_SOFT_PWM
(Source: Kobra_Plus/source/Marlin/src/pins/stm32f1/pins_AC_TRI_F1_V1.h at master · ANYCUBIC-3D/Kobra_Plus · GitHub )
Does anyone have any ideas about why the fans don’t respond to control with Klipper?
Hello @EDACerton !
grafik
I’m missing that line that asks for the klippy.log.
Please attach it to your next post.
klippy.log (40.0 KB)
You have not configured any conditions for these fans.
See
Right… I’m expecting the default behavior for both fans (heater runs when heater enabled, controller runs when steppers enabled).
Klipper shows the desired status, but the actual status doesn’t match (e.g., when I start the printer, the hotend fan says it is off, but the fan starts running at 100%. Same with the controller fan.)
Adding the solution for folks who might find this later:
I updated the MCU, and now the fans respond to control as expected.
