Ask for configured current
445 / 5.000
Resultados de traducción
star_border
Is there any command, by console, to know what is the current to which a driver is configured? I have a Ratrig Vcore3, which has a somewhat messy configuration, since it is in many linked files, and I am not sure what current the extruder driver is configured for, a TMC 2209. I have read that there is a command [dump_tmc] that gives you configuration information… but not the current
DUMP_TMC STEPPER=extruder)
SG_RESULT: 00000000
PWM_AUTO: 000e0024 pwm_ofs_auto=36 pwm_grad_auto=14
PWM_SCALE: 00000007 pwm_scale_sum=7
PWMCONF: c80d0e24 pwm_ofs=36 pwm_grad=14 pwm_freq=1 pwm_autoscale=1 pwm_autograd=1 pwm_reg=8 pwm_lim=1
DRV_STATUS: 80060000 cs_actual=6 stst=1
CHOPCONF: 24020375 toff=5 hstrt=7 hend=6 vsense=1 mres=4(16usteps) dedge=1
MSCURACT: 00ef003c cur_a=60 cur_b=239
MSCNT: 00000028 mscnt=40
TSTEP: 000fffff tstep=1048575
FACTORY_CONF: 0000000c fclktrim=12
IOIN: 21000041 enn=1 pdn_uart=1 version=0x21
OTP_READ: 0000000c otp_fclktrim=12
IFCNT: 00000007 ifcnt=7
GSTAT: 00000001 reset=1(Reset)
GCONF: 000001c4 en_spreadcycle=1 pdn_disable=1 mstep_reg_select=1 multistep_filt=1
========== Queried registers ==========
SGTHRS: 00000000
TPOWERDOWN: 00000014 tpowerdown=20
IHOLD_IRUN: 00081606 ihold=6 irun=22 iholddelay=8
SLAVECONF: 00000200 senddelay=2
========== Write-only registers ==========
it is possible to know which is the current to which a particular driver is configured?
The extruder.
Thank you
If you run the SET_TMC_CURRENT command without any parameters it reports the current. G-Codes - Klipper documentation
Thanks for answer…
Thinking I need the book: Klipper for dummies
