Does anyone know if there is a way to control baby-stepping with the 12864 display & knob like on Marlin?
I found it a handy little option on the marlin firmware to be able to just double-click the knob and adjust baby-stepping live by turning the knob left or right.
Yes, you can - and it should be active during print in the Tune sub-menu:
# This file defines the default layout of the printer's menu.
# It is not necessary to edit this file to change the menu. Instead,
# one may override any of the sections defined here by defining a
# section with the same name in the main printer.cfg config file.
### DEFAULT MENU ###
# Main
# + Tune
# + Speed: 000%
# + Flow: 000%
# + Offset Z:00.00
# + OctoPrint
# + Pause printing
# + Resume printing
# + Abort printing
# + SD Card
# + Start printing
# + Resume printing
# + Pause printing
This file has been truncated. show original
EddyMI3D:
+ Offset Z
Thanks i will check that out!
system
Closed
January 8, 2024, 3:53pm
4
