Printer Model: Ender 3 personalized
MCU / Printerboard: Octopus 1.1v
Hi everyone, klipper doesn’t use my bed mesh
why?
klippy.log (305.4 KB)
why?
Are you actually loading the mesh in the start gcode of the printer or slicer?
Since you never start an actual print in your klippy.log, that info is missing.
Yes, I use “BED_MESH_PROFILE LOAD=default”
How do you come to the impression that the bed mesh is not working?
when I move in X or in Y, klipper doesn’t adjust the Z
[bed_mesh default]
version = 1
points =
0.680000, -0.175000, -1.130000
0.295000, 0.125000, -0.480000
0.000000, 0.280000, 0.280000
Your Z axis is moving less than half a mm in most places, I severely doubt you’re going to notice that kind of movement when the x/y axis is moving too.
To put it into perspective… Those .295 and .280 movements are about the width of a paper towel. It’s EXTREMELY subtle movements.
ok, but when I print, one part comes out thinner and the other thicker, it depends on the position of x and y.
so the bed mesh doesn’t do its job and in any case I set it with the bltouch
How much thinner or thicker are we talking?
Your bed is also skewed quite a bit, Is the Ender 3 bed adjustable? Bed mesh leveling is mainly made for small variations, you have an over 1mm skew from one corner to the other. That’s very large.
I’d try to fix that first.
