Bed_mesh_profile load
How can I change the macro APPLY_BUILD_SHEET_ADJUSTMENT to load a specific bed mesh profile?
I would like to BED_MESH_PROFILE LOAD of a specific sheet when apply build sheet adjustment.
[gcode_macro APPLY_BUILD_SHEET_ADJUSTMENT]
description: Applies the sheet offset adjustment for the installed build sheet, call from your PRINT_START macro
    # get the offset from saved variables
    {% set svv = printer.save_variables.variables %}
    {% set sheet_key = (svv["build_sheet installed"] | string) %}
    {% set sheet = (svv[sheet_key] | default(None)) %}
    {% if sheet %}
        # log this to the console so if there is an issue with the print the user can see which sheet the printer thought it had installed
        {action_respond_info("Applying offset: %.3fmm for build sheet: %s" % (sheet.offset, sheet.name))}
        _BUILD_SHEETS__SET_GCODE_OFFSET Z_ADJUST={sheet.offset} MOVE=1
    {% else %}
        {action_respond_info("No build sheet installed, offset adjustment: 0.000mm") }
Hello @Jura !
Is there a reason you deleted the template?
Please read this:
Excuse mee.### Basic Information:
Printer Model: Custom COREXY
MCU / Printerboard: SKR mini E3 V3.0
Host / SBC CB1
klippy.zip (1.0 MB)
Excuse me.
{% set sheet_key = (svv[“build_sheet installed”] | string) %}
{% if sheet %}
{action_respond_info(“Applying offset: %.3fmm for build sheet: %s” % (sheet.offset, sheet.name))}
{% else %}
{action_respond_info(“No build sheet installed, offset adjustment: 0.000mm”) }
Already solved.
According to the selected sheet, the parameters of the sheet are loaded from Variables.cfg
I solved it with the help of ChatGPT. It is a great helper.
My macro:
[gcode_macro LOAD_BED_PROFILE]
    {% if svv["build_sheet installed"] == "build_sheet smooth_sheet_1" %}
        {action_respond_info("Build sheet is Smooth_sheet_1")}
        BED_MESH_PROFILE LOAD=Smooth_sheet_1
    {% elif svv["build_sheet installed"] == "build_sheet textured_sheet_1" %}
        {action_respond_info("Build sheet is Textured_sheet_1")}
        BED_MESH_PROFILE LOAD=Textured_sheet_1
    {% else %}
        {action_respond_info("Non sheet")}
Obviously you did not read the link entirely.
Code snippets are supposed to be formatted as Preformatted Text
Format
Please edit your posts accordingly. Without that format, the code is useless.
Thank you :grinning:
