BIQU BX MCU protocol error
Printer Model: BIQU BX
MCU / Printerboard: STM32H743/SKR SE-BX V2.0
klippy.log (78.6 KB)
an issue:
After update to klipper v.0.12 I have message like:
"Klipper reports: ERROR
MCU Protocol error
This is frequently caused by running an older version of the
firmware on the MCU(s). Fix by recompiling and flashing the
firmware.
Your Klipper version is: v0.12.0-114-ga77d0790
MCU(s) which should be updated:
CB1: Current version v0.11.0-122-ge6ef48cd
Up-to-date MCU(s):
mcu: Current version v0.12.0-114-ga77d0790
mcu ‘CB1’: Command format mismatch: query_adxl345 oid=%c rest_ticks=%u vs query_adxl345 oid=%c clock=%u rest_ticks=%u""
Recompiling and flashing the firmware is not working. Here is my config
What is the issue?
On my second printer Ender 3 V2 all is working properly.
Hello @KAS !
As for the log, the CB1 version is still 0.11:
Up-to-date MCU(s):
For your post, you try to update the printer board, not the CB1.
Please clarify your statement. I’m not a native English speaker.
I have multiple klipper instances on CB1 board. One is BIQU BX. I posted message I’m receiving after restarting firmware.
I’m confused why there is a problem. On other instance (Ender 3 v2) this problem is not occur, despite similar version mismatch (mcu(stm32f103xe) Version: v0.11.0-304-gf7567a0d ) - (Host(aarch64, 64bit) Version: v0.12.0-114-ga77d0790 ).
I don’t know why in error message (biqu bx) we have:
"CB1: Current version v0.11.0-122-ge6ef48cd
Up-to-date MCU(s):
mcu: Current version v0.12.0-114-ga77d0790"
because klipper version is "klipper
v0.12.0-114-ga77d0790" it seams to be opposite.
Do you know what I should do?
You have to update Klipper on your CB1.
My Klipper is up to date!!
“Your Klipper version is: v0.12.0-114-ga77d0790”
It seems to me that I have to update (Host MCU MCU-like functions on the SBC)
"MCU(s) which should be updated:
CB1: Current version v0.11.0-122-ge6ef48cd"
but I don’t know how!!
I re flashed my printer board via USB
Up-to-date MCU(s):
error persists
Just see here:
Thank you!!!
It can be done via KIAUH
now printer works:
mcu (stm32h743xx)
Load: 0.00, Awake: 0.00, Freq: 400 MHz,
0
mcu CB1 (linux)
Load: 0.03, Awake: 0.00, Freq: 50 MHz,
