BIQU Manta M8P V2 Klipper.cfg
Using the Generic Manta M8P V1.1 klipper config file I, after changing the pin numbers since they a all different then the V1.1 board. I created the firmware, but are unable to connect to the board by USB c or CAN.
Does anyone have Klipper running on Manta M8P V2, because I have a feeling that the assign aliases is wrong as well.
Thanks
What are you using as a host?
Typically, with the Manta boards, you use something like a CM4 or CB1 as the sockets for them are built into the board.
A sample config is available from BTT.
Im using the Biqu pad 7
Thanks, I have been looking everywhere. I see that is different from the one i used. I will try this and let you know. If it works i have to make a link to this, there are many out there looking for this.
BTT publishes everything on their GitHub.
I did go there but since i was using klipper i didn’t think of looking in the firmware folder, for some reason I was thinking it would be marlin in there, even i know the board are made for klipper.
Thanks again.
