PIN is not a valid PIN name on MCU
Printer Model: Voron 2.4 R2 pro plus (Formbot kit)
MCU / Printerboard: BTT Manta m8p + cb1 and EBB SB2209 (RP2024)
Hello everyone,
It’s me again. After two hours of troubleshooting, I’m turning to you again.
I currently have the following error message:
Pin ‘PC10’ is not a valid pin name on mcu ‘mcu’
I checked and the pin fits:
X Stepper on Motor1 (B Motor)
[stepper_x]
step_pin: PE2
dir_pin: PB4
enable_pin: !PC11
rotation_distance: 40
full_steps_per_rotation:200 #set to 400 for 0.9 degree stepper
endstop_pin: EBBCan:gpio24
position_min: 0
position_endstop: 350
position_max: 350
homing_speed: 25 #Max 100
homing_retract_dist: 5
homing_positive_dir: true
Make sure to update below for your relevant driver (2208 or 2209)
[tmc2209 stepper_x]
uart_pin: PC10
interpolate: True
run_current: 0.8
sense_resistor: 0.110
stealthchop_threshold: 0
klippy.log (260.6 KB)
Take it easy. Posting three topics for the same problem won’t help :wink: Old men, don’t rush. You’ll probably get an answer in the end.
What options did you use for make config when you were flashing the Klipper Firmware to your Manta M8P?
I presume you’re using the internal CAN bus, so it should look something like:
From your log:
serial = /tmp/klipper_host_mcu
[mcu EBBCan]
canbus_uuid = afc0a134dc27
[mcu CB1]
canbus_uuid = 500ab1cfdcda
Reason for your error:
  • Your [mcu] is defined as “host MCU” but should be your Manta board and either be connected via CAN (have a canbus_uuid) or via USB-serial and have a board’s serial
  • Your [mcu CB1] is effectively your “host MCU” and should be connected via serial = /tmp/klipper_host_mcu but is defined as “real” MCU with a canbus_uuid
Thanks for the feedback. And yes, it looks exactly the same
Sorry, I don’t get it (mechanical engineer has no idea about software and programming, that has just been confirmed)
I’ve tried several configurations and nothing has worked.
I currently have the error:
mcu ‘EBBCan’: Unable to connect
Can you perhaps tell me what needs to be in my printer.cfg, my manta-m8p-v1.1.cfg and my btt-ebb-sb2209.cfg regarding the mcu. I’ve attached the log again.
Or did I do something wrong when flashing?
Or do you know someone in Germany, in the Ingolstadt or Regensburg area, who can help me? I would then drive over with my printer, I am so desperate right now
klippy.log (502.9 KB)
Since I do not know what you have built and what you intended to built:
  1. Read through Klipper Architecture / Ecosystem to get some understanding how Klipper works
  2. Get the general config here for the Manta: GitHub - bigtreetech/Manta-M8P
    • Note that there are different version of the M8P - choose the correct one
  3. Get the general config for the EBB here: EBB/EBB SB2209 CAN (RP2040)/sample-bigtreetech-ebb-sb-rp2040-canbus-v1.0.cfg at master · bigtreetech/EBB · GitHub
  4. Follow the setup instructions for Klipper here: Installing Klipper with KIAUH
    • Build the respective firmwares according to the connection scheme you want to use (FOLLOW CLOSELY the instructions on top of the cfg files)
    • For the EBB only CAN is applicable
    • For the M8P both USB or CAN could be applicable - You need to choose one according to your wiring
    • Assuming you go by CAN only, obtain your canbus_uuid according to CANBUS - Klipper documentation
  5. Flash both boards with their respective firmware
  6. The representation of the M8P and EBB in your printer.cfg should finally look like (still assuming CAN only):
    [mcu] # This is the M8P
    canbus_uuid: 4b94c57be78e #YOURS WILL BE DIFFERENT - CHANGE IT  TO MATCH
    [mcu EBBCan]
    canbus_uuid: 2f0b1ce14660 #YOURS WILL BE DIFFERENT - CHANGE IT  TO MATCH
  7. Forget about the serial = /tmp/klipper_host_mcu. You likely do not need it, and if you will know.
