Installing Klipper with KIAUH
Preface
The official installation instructions use Octoprint as a control interface. Nowadays, most setups involve Moonraker and fluidd / Mainsail as the primary ways to interact and control a Klipper printer.
The manual configuration of these components is quite involved, so this article will employ KIAUH, a superb shell script that conveniently handles the initial setup process.
This guide will only cover the basic setup, but there is a lot more to discover.
Content
  1. Preface
  2. Initial Considerations
  3. Prepare the Host
    1. Setting up the SD Card
    2. Completing the RPi OS Setup
    3. OS Sanity Checks and Fixes
    4. Accessing the RPi via SSH
  4. Install the Klipper Ecosystem
    1. Install and Run KIAUH
    2. Install Klipper and Associated Products
    3. Build and Flash the Firmware
  5. Configuring Klipper
    1. Initial Configuration
    2. Verify Basic Functionality
  6. Troubleshooting
  7. Fine Tuning and Finishing Touches
For better understanding, some background information:
  • Klipper requires a constant and stable connection between a host process running on a personal computer and the printer board. It is common to use Single Board Computers (SBC) such as the Raspberry Pi, but any current SBC will do the job. See Other Single Board Computers (SBC) apart from Raspberry Pis for more details.
  • The Klipper concept includes several interdependent and interacting products. To gain an understanding of the system, refer to Klipper Architecture / Ecosystem.
  • Some hardware, especially displays, may not have full support from Klipper. It is advisable to carefully examine the configuration files for a particular printer model to ensure that all hardware is compatible. For instance, the absence of a [display] section in a file strongly suggests that the printer’s stock display is not currently supported.
Prepare The Host
On the host computer, a Linux operating system must be running.
  • This guide will assume the use of a Raspberry Pi (RPi).
  • If setting up a different SBC, the approach must be tailored accordingly.
    • For example the popular Armbian distributions offer a comparable approach by using armbian-config as opposed to raspi-config (see below)
    • If you are installing another Linux distribution, in any case, check OS Sanity Checks and Fixes
  • For Raspberry Pi it might be preferable to use 32bit versions, especially when using CAN setups (there are reports of issues with CAN and 64bit Kernels).
  1. Get, install and run the Raspberry Pi Imager
  2. Choose the proper OS you want to use. Popular choices are
    • Mainsail OS (Other specific-purpose OS3D PrintingMainsail OS)
      Mainsail OS comes with Klipper / Mainsail preinstalled, so you can skip installing them later
    • Raspberry Pi OS lite
  3. With the Pi_Img_Settings symbol, some settings can be baked into the image that can make the setup easier:
  4. Prepare the SD card and proceed to boot the RPi with it. It is advisable to connect the RPi to a monitor and keyboard. Some distributions require manual intervention to complete the setup process.
  1. Run sudo raspi-config
    • 1 System OptionsS1 Wireless LANFollow the WIFI setup (skip for using Ethernet)
    • 3 Interface OptionsI2 SSHEnable yes
    • 3 Interface OptionsI4 SPIEnable yes
    • 3 Interface OptionsI5 I2CEnable yes
    • 6 Advanced OptionsA1 Expand Filesystem
  2. Get the IP address of the RPi and write it down. To accomplish this, execute the following command:
    hostname -I
  3. Make sure your Linux is updated to the current state. Run
    sudo apt update
    sudo apt upgrade
  4. Reboot via
    sudo reboot now
This is applicable not only to RPi, but to any Linux OS:
Usually, a monitor is not connected to the RPi and administration is executed “headless” using SSH. In the previous step, the SSH server was enabled, so this access should now work with either the configured or default username, password, and IP address.
After the initial setup is completed, most tasks can get done using the web-based interfaces. Familiarity with these tools, especially when troubleshooting, is strongly recommended.
Common tools to work with SSH are:
  • Windows
  • macOS
  • Linux typically has the options on board already, e.g. in Nautilus, Thunar, Konqueror and the Terminal app.
This chapter outlines the steps necessary to perform a basic setup of Klipper with KIAUH.
Run the following commands:
sudo apt-get install git -y
cd ~
git clone https://github.com/dw-0/kiauh.git
./kiauh/kiauh.sh
In KIAUH follow this simple sequence:
  1. Choose 1) [Install]
  2. Choose 1) [Klipper]
    • Choose Python 3
    • Choose the number of instances. Typically 1, unless you want to run more than one printer off the same host SBC
    • Answer any question about missing group membership with Yes
  3. Followed by 2) [Moonraker]
  4. Install the web-interface of your choice: 3) [Mainsail] and / or 4) [Fluidd]
    • Installing both is possible
    • The first one installed will be accessible via port 80, the second one via the port given during installation, e.g. 81
    • Confirm questions about downloading any macro files.
  5. Hit B to go back to main menu
  6. On your main personal computer, use your browser to navigate to
    http://the_IP_you_noted_earlier/
    to access the web-interface for the first time
  7. Download the appropriate configuration file for your printer / printer-board (screenshots from fluidd)
    • Move to Configuration (Machine in Mainsail) in the left-hand side menu
      fluidd1
    • Choose Other FilesConfig_Examples (Drop-down in Mainsail)
    • Select the matching printer model or board, right click and select Download
  8. Open the downloaded file in a proper editor, e.g. Notepad++ (Windows only) or Sublime Text (also macOS)
In the previous step, the installation of the host components on the SBC was completed. The next task is to build and flash the firmware component on the printer-boards.
  1. Carefully review the initial lines of the configuration file downloaded in the preceding step, as it contains important information.
    • It provides instructions on how to build the firmware and which build settings to choose
    • Information how to install it on the Printer-Board
  2. To build the firmware, select 4) [Advanced] and then 2) [Build only] in KIAUH.
  3. Enter the information from the configuration file in the screen that appears. To establish a connection to the board later on, it is crucial to adhere to all settings.
    • Complete the setup by selecting Q to confirm and save the settings.
  4. The firmware file will be generated at ~/klipper/out/klipper.bin. Flash the board based on the instructions provided in the configuration file.
    • The flashing functions in KIAUH under 4) [Advanced] can be used as well, but for the first time setup, the manual approach is recommended
    • If the instructions call for a specific flashing command, the command
      ls /dev/serial/by-id/*
      will provide the required target address
    • The most common command to flash the board is (also used if no other specific command is mentioned in the configuration file):
      sudo service klipper stop
      make flash FLASH_DEVICE=<the_complete_target_address_from_above>
      sudo service klipper start
    • If the instructions call for copying the bin-file to the SD card, tools like the above-mentioned WinSCP can be used. Only copy and potentially rename the klipper.bin to a SD card, not the entire folder
Configuring Klipper
  1. In KIAUH call 4) [Advanced] and then 5) [Get MCU ID] or run the command
    in the shell.
  2. Copy the complete path as displayed, e.g.
    /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
  3. Paste the copied address into the configuration file that has been downloaded and opened in a editor above. It should then look like:
     serial: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
  4. Also add the web interface specific macro to the configuration file. This can either be fluidd.cfg or mainsail.cfg depending on the web interface that is used. The config shall then include a section like
    [include fluidd.cfg] # Alternatively: [include mainsail.cfg]
    • Do not add both. One of them is sufficient for both web interfaces
    • Note that this file contains macro definitions for CANCEL_PRINT, PAUSE, RESUME etc. Avoid adding duplicate definitions anywhere else in the configuration files.
    • For further information, refer to Mainsail Configuration
  5. Save the adapted configuration as printer.cfg
  6. Upload the printer.cfg via the Configuration section in the web interface (Mainsail dropdown → config). The default path on OS level is ~/printer_data/config
  7. Restart Klipper either via the web interface or via issuing the command sudo systemctl restart klipper
With the above steps, the basic setup is completed and the web interface should show the temperatures of the bed and extruder and not display any errors.
The following step should now be performed to ensure a proper basic functionality: Configuration Checks and, if using a BLTouch (or clone), its Initial Tests.
Troubleshooting
If there are any problems or error messages at the end of this simple installation process, it is time to troubleshoot your installation.
  • Carefully work through How-To Trouble-Shoot and check About the Knowledge Base category / Table of Contents. Almost all typical errors are covered there
  • Reviewing the klippy.log file is necessary for all troubleshooting purposes. On the web interfaces, it’s easy to access or download and is prominently displayed on the home or dashboard page if there are any errors.
  • If you encounter unanticipated or irregular behavior, the klippy.log can also be a helpful resource. It is always accessible via the navigation bar on the left side of the screen under Configuration (fluidd) or Machine (Mainsail).
  • If you require aid, attach the klippy.log to your post at all times. Posts without the log will not receive a response. Use any compression tool like zip if the file is too big to attach.
The following steps are optional but will enhance the printing experience and quality:
  1. Check and adjust potentially twisted X axis (requires a probe)
  2. Perform bed_leveling
  3. Create a bed_mesh (requires a probe)
  4. Compensate for detrimental resonances (requires an Inertial Measurement Unit for the automatic process)
  5. Calibrate the extruder’s rotation_distance
  6. Dial in Pressure Advance for your filaments
No serial found
Possibly Bricked my board
Klipper worth installing? Using PETG only
Ender 3 btt skr 3 ez
Kobra plus flash. What am I doing wrong
Unable to get printer to connect to klipper
The printer is not ready on Klipper
Mcu connection error durring new install
PI4B CB1 not able to connect to SKR 1.4 Turbo
Having trouble connecting klipper
Files for Tronxy X5SA-400 Pro?
Hello everyone,UART received data garbled characters
PIN Name not accepted by MCU
Anycubic Kobra Neo - Connection issue
Move out of range when PROBE_CALIBRATE
Problems with Btt Manta M8P bootloader
MCU unable to connect. Own Build
Can’t connect to klipper
Troubleshooting Klipper and reviewing logs
Raspberry can't find Wanhao Duplicator d12/300 USB printer
Ender 3 v2 board 4.2.2, not able to flash Klipper firmware
Cannot find MCU?
Connection to MCU Issue
Clarifying Questions!
Geeetech a10t and klipper
Klipper protocol / startup
Klipper, linux on loptop, MCU, lsusb, CH340
Can't find usb id for BTT CB1+M8p
Kiauh trouble with files
Question Abt Klipper New Install
Arduino uno ATmega328PB CH340G
Getting started on dremel 3D45
Honestly im about to give up on klipper, its just getting ridiculous at this point
Problem with flashing firmware
Unable to open file error, I've tried everything
BED_MESH_CALIBRATE PROFILE="default" fails
Flashing process issue
Imprimante sovol sur klipper
Everything works except Heaters
Homers tevo tarantula pro .bin y .cfg
No MCU detected - raspberry pi 3
PIN is not a valid PIN name on MCU
Fresh Install of Klipper/Mainsail and Fluidd
Lost MCU path after hardware change
Printer main board not flashing klipper
Installing Klipper manually
PSA: CanBus on 32 Bit vs 64 Bit Pi's - "Communication timeout" errors
