Failed Klipper install using kiauh
Printer Model: ender 3
MCU / Printer-board: stock
Describe your issue: I am new to kipper and have been having some trouble getting the install to complete on my raspberry pi 3b+ using ssh
this is the last part the terminal said:
Cloning Klipper from GitHub - Klipper3d/klipper: Klipper is a 3d-printer firmware …
Cloning into ‘/home/pi/klipper’…
remote: Enumerating objects: 58590, done.
remote: Counting objects: 100% (51/51), done.
remote: Compressing objects: 100% (38/38), done.
remote: Total 58590 (delta 29), reused 19 (delta 13), pack-reused 58539
Receiving objects: 100% (58590/58590), 163.34 MiB | 6.02 MiB/s, done.
client_loop: send disconnect: Broken pipe
What distro are you using? Have you tried modifying the system files? For what were you using this system before trying to use kiauh, what is installed on the system manually?
I managed to get it working turns out it was a power supply issue.
