BIQU MicroProbe V2.0 on Spider with Klipper?
short tested weak pull up, worked fine
the BIQU is now mounted on the Z-Max strong pull up
Klipper tells me ā€œunknown command M17ā€
just want to power the z driver
[homing_override]
set_position_z:0
    M17 Z
    G28 Y
    G28 X
    G1 x245 y215 f10000
    G28 Z
    G1 Z400
Oh, come on @4711Austria.
  • You hang around here for some time so you should know the official Klipper documentation
  • Does it mention to support M17? → No, it does not.
  • Did I already provide you with a link to the relevant function in Klipper? → Yes, 5 posts up
I’m happy to help, but when I get the feeling that I’m the ā€œplease aunty, read for me the official documentationā€, then it starts to annoy me.
Sorry if you feel like that, this is not my intention.
I cannot see a M17 in the Klipper Doc/Wiki, so I have to ask. Now I know there isn’t, ok, but cannot really beleave.
just figured out, that the BIQU does not stow the probe after referencing
on my seconde print the probe is already bended… perfect.
tried the macro code inside the homing-override, does not do anything
have to figure out, how is the command in the printer.cfg to stow before referencing and after
this solved the problem:
[homing_override]
set_position_z:0
    Probe_Stow
    G28 Y
    G28 X
    G1 x245 y215 f10000
    G28 Z
    Probe_Deploy
    Probe_Stow
    G1 Z400
For the record, there is a 10k resistor for the bltouch pin that’s connected to z_min at least for Spider v2.3.
Screenshot 2024-02-14 233308
