BL Touch Probe is not trigger during Z_Min Homing
BL Touch
Start up = probe getting up and down
I can run commands pin_down / pin_up its works perfectly and the led light is also ON OFF according.
when sending BLTOUCH_DEBUG COMMAND=touch_mode
showing Probe: Open
Then while gently pushing the pin up slightly with the nail ans send QUERY_PROBE
also showing Probe: Open. It’s not getting triggered.
I am using MKS Eagle motherboard, and Printer kinematics is cartesian
following is my configration for BL Touch.
step_pin: PB5
dir_pin: PB4
enable_pin: !PB8
rotation_distance: 8
position_max: 400
position_min: -5
homing_speed = 10
homing_retract_dist = 5
second_homing_speed = 3
[bltouch]
sensor_pin: ^PC8
control_pin: PA8
x_offset: -8.05
y_offset: 23.28
z_offset: 1.85
stow_on_each_sample: True: True
probe_with_touch_mode: False
[safe_z_home]
home_xy_position: 160,160
speed: 150
z_hop: 10
z_hop_speed: 5
[bed_mesh]
speed: 200
horizontal_move_z: 5
mesh_min: 30,30
mesh_max: 290,290
probe_count: 5,5
fade_start: 1
fade_end: 10
algorithm: bicubic
[gcode_macro G29]
G28
BED_MESH_CALIBRATE
G1 X0 Y0 Z5 F4000
Please help me to solve this problem.
Thank you!
Genuine BLTouch or clone?
For clones this behavior has been reported before but they will work anyway during a real homing.
Follow BL-Touch - Klipper documentation (last two paragraphs under “Initial Tests”)
and BL-Touch - Klipper documentation for information about clones.
Thank you for your reply, Did the same thing as per the documents but the same problem I am facing.
Also when I am using the same BL Touch in marlin firmware for Z_Min homing its works perfectly… While in Klipper it’s not triggered.
