Printer Model: CR10 V3
MCU / Printerboard: AVR atmega2560
Fill out above information and in
klippy.log (3.7 MB)
all cases attach your klippy.log file. Pasting your printer.cfg is not needed
When pasting code or config snippets use the code tags </> in the menu above
I am new to Klipper and I have some problem getting the BTT Smart Filament Sensor working in certain condition. The BTT sensor now can detect filament runout but it seems it doesn’t work when I test the scenario of filament jam. I tried to hold the filament tight and created the tangling situation but BTT cannot detect it. If it is run-out it is fine. Anyone has the similar situation?Thanks!
