Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
…BTT kraken can’t get limit switches to work. Steppers, heater, thermistor all work. But cant get the limit switches to do anything
I have tried signal and ground, 5v and ground.
! ^ in the config and no matter what they will not change status when triggered.
-If the end stops are just microswitches without a board, you may not be using the correct terminals on the microswitch.
-if the end stops have a PCB (board) as a part of the end stop, then we need a photo and information from those boards. These typically require signal, ground, 3.3-5V to work correctly.
I figured it out it was my mistake. Long story short. Default on the board is NC my switches were NO. 2 wire limit switches use ground and signal I added an “!” To end stop on config.
However the problem is now the endstops work intermittently sometimes they work perfect and other times they crash into my printer violently
