Hey
I try to get my “PL-08N2 NPN NC” probe running on the Btt Octopus 1.1.
V+ and Ground are wired direcly to the PS.
Signal is conectet to the signal pin PB7 (Sensor Port) Jumper set to 24V.
I run my printer in this config for months with marlin.
Now i tried to switch to klipper and always get the same error:
File contains parsing errors: /home/pi/printer.cfg
[line 574]: ’ pin: ~PB7\n
I already tried : ~PB7; ~!PB7; PB7; !PB7; ^PB7; ^!PB7; ~^PB7; ~^!PB7
without any result.
Her´s my log:
Restarting printer
Start printer at Tue Apr 5 20:24:47 2022 (1649186687.6 2811.6)
Config error
File “/home/pi/klipper/klippy/klippy.py”, line 157, in _connect
self._read_config()
File “/home/pi/klipper/klippy/klippy.py”, line 134, in _read_config
config = pconfig.read_main_config()
File “/home/pi/klipper/klippy/configfile.py”, line 276, in read_main_config
regular_config = self._build_config_wrapper(regular_data, filename)
File “/home/pi/klipper/klippy/configfile.py”, line 263, in _build_config_wrapper
self._parse_config(data, filename, fileconfig, set())
File “/home/pi/klipper/klippy/configfile.py”, line 255, in _parse_config
self._parse_config_buffer(buffer, filename, fileconfig)
File “/home/pi/klipper/klippy/configfile.py”, line 215, in _parse_config_buffer
fileconfig.readfp(sbuffer, filename)
File “/usr/lib/python2.7/ConfigParser.py”, line 324, in readfp
self._read(fp, filename)
File “/usr/lib/python2.7/ConfigParser.py”, line 546, in _read
raise e
ParsingError: File contains parsing errors: /home/pi/printer.cfg
[line 574]: ’ pin: ~PB7\n’
Printer is halted
Klipper state: Not ready
I really running out of ideas …
