Printer Model: Sidewinder X1
MCU / Printerboard: SKR 1.4 (None Turbo)
klippy.log (802.1 KB)
I unable to home x y and z or turn on the extruder to test the temperature, can anyone point me the direction how to diagnose the issue or solution?
Have you used the example config it looks right in x, y and z against marlin pins
# This file contains common pin mappings for the BIGTREETECH SKR V1.4
# board. To use this config, the firmware should be compiled for the
# LPC1768 or LPC1769(Turbo).
[stepper_x]
step_pin: P2.2
dir_pin: P2.6
enable_pin: !P2.1
rotation_distance: 40
endstop_pin: !P1.29
position_endstop: 0
position_max: 235
homing_speed: 50
[stepper_y]
step_pin: P0.19
dir_pin: P0.20
This file has been truncated. show original
* Marlin 3D Printer Firmware
* Copyright (c) 2020 MarlinFirmware [https://github.com/MarlinFirmware/Marlin]
* Based on Sprinter and grbl.
* Copyright (c) 2011 Camiel Gubbels / Erik van der Zalm
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <https://www.gnu.org/licenses/>.
