Bug caused thermal runaway and might have been catastropic
Voron 2.4
SB2040, SBB Octopus
I think that there is a bug in the thermal runaway detection.
I have a sb2040 over canbus, and I have not had any indication that there should be any hardware issues (loose wires, etc.)
Hotend is a rapido which has a good thermistor connection.
Here is the relevant section of the log file…
Stats 265.4: gcodein=0  mcu: mcu_awake=0.135 mcu_task_avg=0.000147 mcu_task_stddev=0.000124 bytes_write=792073 bytes_read=167554 bytes_retransmit=9 bytes_invalid=0 send_seq=20280 receive_seq=20280 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001704 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=4633 bytes_read=31314 bytes_retransmit=0 bytes_invalid=0 send_seq=494 receive_seq=494 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999878 mmu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000013 bytes_write=2906 bytes_read=49815 bytes_retransmit=9 bytes_invalid=0 send_seq=389 receive_seq=389 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47993394 adj=47992517  toolhead: temp=38.3 raspberry_pi: temp=41.4 mcu_temp: temp=40.3 heater_bed: target=0 temp=45.5 pwm=0.000 sysload=0.41 cputime=30.286 memavail=1552108 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-26.9 pwm=1.000
Stats 266.4: gcodein=0  mcu: mcu_awake=0.135 mcu_task_avg=0.000147 mcu_task_stddev=0.000124 bytes_write=792203 bytes_read=167818 bytes_retransmit=9 bytes_invalid=0 send_seq=20285 receive_seq=20285 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001698 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=4639 bytes_read=31417 bytes_retransmit=0 bytes_invalid=0 send_seq=495 receive_seq=495 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999862 mmu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000013 bytes_write=2912 bytes_read=49830 bytes_retransmit=9 bytes_invalid=0 send_seq=390 receive_seq=390 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47993387 adj=47992487  toolhead: temp=38.2 raspberry_pi: temp=41.4 mcu_temp: temp=40.4 heater_bed: target=0 temp=45.4 pwm=0.000 sysload=0.41 cputime=30.331 memavail=1552108 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-23.1 pwm=1.000
Stats 267.4: gcodein=0  mcu: mcu_awake=0.135 mcu_task_avg=0.000147 mcu_task_stddev=0.000124 bytes_write=792311 bytes_read=168025 bytes_retransmit=9 bytes_invalid=0 send_seq=20290 receive_seq=20290 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001692 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=4645 bytes_read=31520 bytes_retransmit=0 bytes_invalid=0 send_seq=496 receive_seq=496 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000002 adj=11999869 mmu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000013 bytes_write=2918 bytes_read=49846 bytes_retransmit=9 bytes_invalid=0 send_seq=391 receive_seq=391 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47993380 adj=47992509  toolhead: temp=38.3 raspberry_pi: temp=41.9 mcu_temp: temp=40.2 heater_bed: target=0 temp=45.4 pwm=0.000 sysload=0.41 cputime=30.374 memavail=1555336 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-26.2 pwm=1.000
Stats 268.4: gcodein=0  mcu: mcu_awake=0.040 mcu_task_avg=0.000097 mcu_task_stddev=0.000271 bytes_write=792407 bytes_read=168261 bytes_retransmit=9 bytes_invalid=0 send_seq=20296 receive_seq=20296 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001683 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=4666 bytes_read=31664 bytes_retransmit=0 bytes_invalid=0 send_seq=498 receive_seq=498 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000002 adj=11999877 mmu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000013 bytes_write=2924 bytes_read=49862 bytes_retransmit=9 bytes_invalid=0 send_seq=392 receive_seq=392 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47993374 adj=47992532  toolhead: temp=38.3 raspberry_pi: temp=42.4 mcu_temp: temp=40.4 heater_bed: target=0 temp=45.4 pwm=0.000 sysload=0.41 cputime=30.420 memavail=1555192 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-24.0 pwm=1.000
<snip>
(and it continues for 100 seconds without halting the printer.)
The thermal runaway starts at line 5024 of the attached log.
If you scroll up you will notice a shutdown proceeded by a single negative thermistor result.
I would suggest that ANY thermistor reading in the negative should trigger an immediate shutdown. I suspect there is a bug in the state machine at verify_heater.py, line 87.
My guess is that because the target temperature didn’t change, the detection block was never entered, but I can’t verify this after the fact.
klippy thermal runaway.log (558.1 KB)
From reading through the log it looks like the MCU shutdown was performed when the first negative reading occurred. Never the less, the printer DID NOT shutdown, and only avoided a fire when the power switch was shut off.
If that is the case, perhaps the PWM for the heater should first be set to zero before a full machine SCRAM to avoid this as a possibility?
This issue might be related? Potential bug in Thermal runaway protection. (keeps heating forever!) - General Discussion - Klipper
It appears Klipper shut down appropriately, and nothing more can be done here. When Klipper enters a shutdown state it turns off all heaters. If the hotend was still heating after the shutdown, then it was a hardware problem.
If klipper was shutdown, why was it still logging to the log file for a few minutes?
Klipper went into shutdown state but the klippy.py host process remained active and logging as intended.
So what I am understanding is that the klipper process running on my raspberry pi board told the sb2040 to shut down. The sb2040 DID NOT shut down, and continued passing PWM=1.0 to the heater, which was happily sent back to the logging service and stored on the disk.
That doesn’t sound like a hardware issue. That sounds like the klipper software running on the SB2040 failed to shut down as requested.
Or am I missing something here?
That does appear to be consistent with the log:
EDIT: Per @koconnor in the comment below, the log does indicate that the heater was commanded off and the appearance in the graph below that the heater power remained at full after the shutdown is just the mcu reporting its last request:
Do you know whether the heater in fact remained at full power and continued heating after the shutdown?
That is a misunderstanding of the log.
The log indicates that the host detected a heating error (Transition to shutdown state: Heater extruder not heating at expected rate) and commanded all the MCUs to shutdown. The sb2040 successfully reported shutdown (MCU 'sb2040' shutdown: Command request). The MCU code is designed to command all heaters off in the event of a shutdown request. After that point, both the host and mcus are in a “shutdown state” designed so that they no longer process further requests (at least until the state is explicitly cleared with a FIRMWARE_RESTART command).
The log continues to report pwm=1.00 because of a quirk in how log reporting is done. Since the heater code is no longer running, it is just reporting its last request - it can’t make new requests because the MCU and host are both in a “no new requests state”. The shutdown itself, however, does indicate that the sb2040 MCU commanded the heater off. If the heater did not turn off, it generally indicates that the hardware had malfunctioned and the software was no longer able to command it.
Typically when the printer enters a shutdown state I’m aware of it due to all the fans turning on (its loud.)
In this case, I had my back to the printer and noticed the smell of burning plastic (not that strong.)
I turned around to the Voron with a completely filled case of smoke, and a considerable amount of smoke being pushed out the nozzle.
I then flipped the wall switch to disconnect power.
I did not recall hearing the fans go on full like normal during a typical shutdown event, and I think I would have notice that and turned sooner rather than noticing the smell first.
I often print at various levels of ‘unattended’ relying on fire detectors in the room to provide a backup in the case of the unthinkable. In this case the smoke was contained in the case and did not trigger the alarm.
Needless to say, I would like to track this down so that I can begin to trust printing.
The only possible cause I can come up with is that the printer was recently homed at the start of a print, bringing the toolhead to the back. The thermistor connection could have come in contact with the cable z track leading to the noise in the signal that should have triggered the shutdown. I haven’t seen anything like that since.
I’m perplexed.
Hello Kevin. I have managed to reproduce the bug a second time. The printer tried to catch on fire and had another thermal runaway.
This time it occurred at print start, just after bed mesh.
The printer DID move to a paused state, but the toolhead continued to heat. There was no chance of a short or physical hardware failure.
Some interesting things seen in the log just before :
Write g-code response
  File "/home/pi/klipper/klippy/gcode.py", line 459, in _respond_raw
    os.write(self.fd, (msg+"\n").encode())
BlockingIOError: [Errno 11] Resource temporarily unavailable
Here is where it catches the temp is zero and tries to shutdown the mmu:
  35  | (20.0, 290.2)   | (20.0, 310.0)
bed_mesh: zero_reference_position is (226.66, 309.98)
Starting heater checks for extruder
- DEBUG: Loaded persisted MMU state, level: 0
- DEBUG: LEDs support is not configured
Stats 2402.6: gcodein=0  mcu: mcu_awake=0.007 mcu_task_avg=0.000008 mcu_task_stddev=0.000048 bytes_write=3285 bytes_read=6367 bytes_retransmit=9 bytes_invalid=0 send_seq=265 receive_seq=265 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=3152 freq=180003958 sb2040: mcu_awake=0.017 mcu_task_avg=0.000021 mcu_task_stddev=0.000033 bytes_write=1377 bytes_read=4719 bytes_retransmit=0 bytes_invalid=0 send_seq=143 receive_seq=143 retransmit_seq=0 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000564 adj=12000779 mmu: mcu_awake=0.012 mcu_task_avg=0.000019 mcu_task_stddev=0.000031 bytes_write=1462 bytes_read=4611 bytes_retransmit=9 bytes_invalid=0 send_seq=151 receive_seq=151 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47995252 adj=47994148  toolhead: temp=0.0 raspberry_pi: temp=38.9 mcu_temp: temp=0.0 heater_bed: target=0 temp=0.0 pwm=0.000 sysload=0.31 cputime=321.576 memavail=1538424 print_time=4.798 buffer_time=0.000 print_stall=0 extruder: target=0 temp=0.0 pwm=0.000
webhooks: registering remote method 'shutdown_machine' for connection id: 4077732976
webhooks: registering remote method 'reboot_machine' for connection id: 4077732976
webhooks: registering remote method 'pause_job_queue' for connection id: 4077732976
webhooks: registering remote method 'start_job_queue' for connection id: 4077732976
webhooks: registering remote method 'spoolman_get_filaments' for connection id: 4077732976
webhooks: registering remote method 'spoolman_set_active_spool' for connection id: 4077732976
MCU 'sb2040' shutdown: ADC out of range
Note that the mmu DOES NOT shut down.
I’m guessing that the canbus goes down and it never receives the shutdown message.
Is there a way to improve the logging for the SB2040 so that we can see if it ever gets the canbus message?
Also, is the SB2040 at the toolhead doing the PID loop? Or is that still being driven from my main octopus board?
Most important question:
Can’t the SB2040 running klipper see that the temp is out of range and shut itself down?
Without touching the printer, reboot restores the reading of the thermistor and rules out any issues caused by momentary movement (such as a wire tugged.)
I should mention I’m on canbus, so not much can get pulled. The thermistor wire is very short, and goes straight to the sb2040
I get this error and callstack when the machine reboots:
Printer is shutdown
Script running error
File “/home/pi/klipper/klippy/extras/delayed_gcode.py”, line 34, in _gcode_timer_event
self.gcode.run_script(self.timer_gcode.render())
File “/home/pi/klipper/klippy/gcode.py”, line 229, in run_script
self._process_commands(script.split(‘\n’), need_ack=False)
File “/home/pi/klipper/klippy/gcode.py”, line 211, in _process_commands
handler(gcmd)
File “/home/pi/klipper/klippy/gcode.py”, line 285, in cmd_default
raise gcmd.error(self.printer.get_state_message()[0])
gcode.CommandError: MCU ‘sb2040’ shutdown: ADC out of range
Have you verified that the mosfet on the SB2040 is not failing? I also don’t understand why the printer would move to a paused state in a thermal runaway event. It should shut everything down immediately, but you’ve not posted a new log to evaluate so all we can do is guess what happened.
Mosfet was verified to be closed by checking pins p6 and vcc and determining they are not connected (circuit open.)
Board was pulled and examined under magnification for damage. Nothing apparent.
Thermistor connection was manipulated with the board only connected to power, no abnormal values were observed. Not even tiny noise.
I can only conclude that something in the mcu is telling the mosfet to stay on.
Some other information:
  1. This was running for over a year with no issues prior to a klipper mcu update right before the first event.
  2. The second runaway occurred with a completely new hotend and wiring. Thermistor and heater are different. Only common component is the SB2040 between the two events.
  3. The failure occurred during bed probing, the next klipper log message after “Starting heater checks for extruder” results in a temp of zero.
  4. Both failures occurred early in the print process, at homing or bed mesh time.
Full log is incoming.
Attached log file:
klippy.log (1.6 MB)
The question came up: Can we debug if the SB2040 is really shut down?
The answer is: YES!
I videoed the thermal runaway.
During the runaway event the led that controls the heater displays flashes (PWM) so indeed the MCU is sending a “please heat” signal to the heater in a cycle.
In addition, the animation of the leds on the stealthburner toolhead continues to animate (addressable color LED’s), another process that is controlled by Klipper running at the toolhead.
@koconnor would these be on another thread that would continue after the shutdown event occurs? Is this a false conclusion?
@koconnor
If the MCU is in shutdown state and that pwm=1.000 value is just a logging quirk, what are the changing temp= values? If the MCU is not running, how can it still report different temps then?
Also, why did, as SailMad reported, the fans not start when the MCUs entered shutdown state? Same as with the LED animation of his toolhead. This wouldn’t be the case without the mcu still running.
Also, think about it, the underlying hardware issue is apparently a sensor reporting false values. What other non-software related issue could cause the PWM not being turned off? A stuck MOSFET? At the same time as sensors reporting wrong values? Could be, but seems as likely as winning the lottery. Twice in a row, as Sailmed had the problem a 2nd time.
Or the MCU crashing with the PWMs staying on? Same, why would that happen in coincidence, twice in a row. very unlikely. And, even if that was the case, it should’ve been catched by the watchdog.
Only possible explanation is software bug.
Stats 339.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796465 bytes_read=181057 bytes_retransmit=9 bytes_invalid=0 send_seq=20510 receive_seq=20510 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001735 sb2040: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000022 bytes_write=5343 bytes_read=40064 bytes_retransmit=0 bytes_invalid=0 send_seq=585 receive_seq=585 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000005 adj=11999906 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3356 bytes_read=51209 bytes_retransmit=9 bytes_invalid=0 send_seq=464 receive_seq=464 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994012 adj=47994096  toolhead: temp=37.4 raspberry_pi: temp=37.0 mcu_temp: temp=38.3 heater_bed: target=0 temp=44.6 pwm=0.000 sysload=0.38 cputime=36.495 memavail=1563068 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-21.7 pwm=1.000
Stats 340.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796579 bytes_read=181321 bytes_retransmit=9 bytes_invalid=0 send_seq=20515 receive_seq=20515 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001731 sb2040: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000022 bytes_write=5349 bytes_read=40182 bytes_retransmit=0 bytes_invalid=0 send_seq=586 receive_seq=586 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999873 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3362 bytes_read=51225 bytes_retransmit=9 bytes_invalid=0 send_seq=465 receive_seq=465 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994021 adj=47994002  toolhead: temp=37.5 raspberry_pi: temp=38.0 mcu_temp: temp=38.3 heater_bed: target=0 temp=44.6 pwm=0.000 sysload=0.43 cputime=36.586 memavail=1562140 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-26.7 pwm=1.000
Stats 341.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796638 bytes_read=181490 bytes_retransmit=9 bytes_invalid=0 send_seq=20518 receive_seq=20518 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001727 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5355 bytes_read=40299 bytes_retransmit=0 bytes_invalid=0 send_seq=587 receive_seq=587 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999880 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3368 bytes_read=51241 bytes_retransmit=9 bytes_invalid=0 send_seq=466 receive_seq=466 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994034 adj=47994042  toolhead: temp=37.3 raspberry_pi: temp=37.5 mcu_temp: temp=38.2 heater_bed: target=0 temp=44.6 pwm=0.000 sysload=0.43 cputime=36.673 memavail=1561692 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-25.6 pwm=1.000
Stats 342.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796693 bytes_read=181659 bytes_retransmit=9 bytes_invalid=0 send_seq=20521 receive_seq=20521 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001724 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5361 bytes_read=40416 bytes_retransmit=0 bytes_invalid=0 send_seq=588 receive_seq=588 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999880 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3374 bytes_read=51257 bytes_retransmit=9 bytes_invalid=0 send_seq=467 receive_seq=467 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994042 adj=47994140  toolhead: temp=37.6 raspberry_pi: temp=37.5 mcu_temp: temp=38.2 heater_bed: target=0 temp=44.6 pwm=0.000 sysload=0.43 cputime=36.761 memavail=1561440 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-23.8 pwm=1.000
Stats 343.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796699 bytes_read=181791 bytes_retransmit=9 bytes_invalid=0 send_seq=20522 receive_seq=20522 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001722 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5382 bytes_read=40546 bytes_retransmit=0 bytes_invalid=0 send_seq=590 receive_seq=590 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999882 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3380 bytes_read=51273 bytes_retransmit=9 bytes_invalid=0 send_seq=468 receive_seq=468 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994054 adj=47994139  toolhead: temp=37.6 raspberry_pi: temp=38.9 mcu_temp: temp=38.2 heater_bed: target=0 temp=44.6 pwm=0.000 sysload=0.43 cputime=36.849 memavail=1560992 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-24.4 pwm=1.000
Stats 344.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796705 bytes_read=181908 bytes_retransmit=9 bytes_invalid=0 send_seq=20523 receive_seq=20523 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001723 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5388 bytes_read=40647 bytes_retransmit=0 bytes_invalid=0 send_seq=591 receive_seq=591 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999882 mmu: mcu_awake=0.001 mcu_task_avg=0.000010 mcu_task_stddev=0.000009 bytes_write=3386 bytes_read=51302 bytes_retransmit=9 bytes_invalid=0 send_seq=469 receive_seq=469 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994069 adj=47994204  toolhead: temp=37.0 raspberry_pi: temp=38.5 mcu_temp: temp=38.2 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.43 cputime=36.937 memavail=1560768 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-25.2 pwm=1.000
Stats 345.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796760 bytes_read=182077 bytes_retransmit=9 bytes_invalid=0 send_seq=20526 receive_seq=20526 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001722 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5394 bytes_read=40756 bytes_retransmit=0 bytes_invalid=0 send_seq=592 receive_seq=592 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999877 mmu: mcu_awake=0.001 mcu_task_avg=0.000010 mcu_task_stddev=0.000009 bytes_write=3392 bytes_read=51318 bytes_retransmit=9 bytes_invalid=0 send_seq=470 receive_seq=470 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994076 adj=47994287  toolhead: temp=37.3 raspberry_pi: temp=37.5 mcu_temp: temp=38.2 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.48 cputime=37.029 memavail=1560336 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-24.6 pwm=1.000
Stats 346.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796815 bytes_read=182275 bytes_retransmit=9 bytes_invalid=0 send_seq=20529 receive_seq=20529 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001717 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5400 bytes_read=40880 bytes_retransmit=0 bytes_invalid=0 send_seq=593 receive_seq=593 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999885 mmu: mcu_awake=0.001 mcu_task_avg=0.000010 mcu_task_stddev=0.000009 bytes_write=3398 bytes_read=51334 bytes_retransmit=9 bytes_invalid=0 send_seq=471 receive_seq=471 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994086 adj=47994229  toolhead: temp=36.9 raspberry_pi: temp=37.0 mcu_temp: temp=38.2 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.48 cputime=37.119 memavail=1559664 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-27.6 pwm=1.000
Stats 347.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796870 bytes_read=182444 bytes_retransmit=9 bytes_invalid=0 send_seq=20532 receive_seq=20532 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001715 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5406 bytes_read=40976 bytes_retransmit=0 bytes_invalid=0 send_seq=594 receive_seq=594 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999887 mmu: mcu_awake=0.001 mcu_task_avg=0.000010 mcu_task_stddev=0.000009 bytes_write=3404 bytes_read=51350 bytes_retransmit=9 bytes_invalid=0 send_seq=472 receive_seq=472 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994093 adj=47994258  toolhead: temp=37.5 raspberry_pi: temp=38.5 mcu_temp: temp=38.0 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.48 cputime=37.207 memavail=1559664 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-24.3 pwm=1.000
Stats 348.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=796974 bytes_read=182679 bytes_retransmit=9 bytes_invalid=0 send_seq=20537 receive_seq=20537 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001730 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5427 bytes_read=41097 bytes_retransmit=0 bytes_invalid=0 send_seq=596 receive_seq=596 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999886 mmu: mcu_awake=0.001 mcu_task_avg=0.000010 mcu_task_stddev=0.000009 bytes_write=3410 bytes_read=51366 bytes_retransmit=9 bytes_invalid=0 send_seq=473 receive_seq=473 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994097 adj=47994217  toolhead: temp=37.2 raspberry_pi: temp=38.0 mcu_temp: temp=38.0 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.48 cputime=37.295 memavail=1559664 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-28.2 pwm=1.000
Stats 349.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797083 bytes_read=182957 bytes_retransmit=9 bytes_invalid=0 send_seq=20542 receive_seq=20542 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001728 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5433 bytes_read=41207 bytes_retransmit=0 bytes_invalid=0 send_seq=597 receive_seq=597 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000002 adj=11999870 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3416 bytes_read=51395 bytes_retransmit=9 bytes_invalid=0 send_seq=474 receive_seq=474 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994099 adj=47994072  toolhead: temp=37.3 raspberry_pi: temp=37.5 mcu_temp: temp=38.1 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.48 cputime=37.385 memavail=1558992 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-25.9 pwm=1.000
Stats 350.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797143 bytes_read=183121 bytes_retransmit=9 bytes_invalid=0 send_seq=20545 receive_seq=20545 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001724 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000022 bytes_write=5439 bytes_read=41303 bytes_retransmit=0 bytes_invalid=0 send_seq=598 receive_seq=598 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000002 adj=11999871 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3422 bytes_read=51411 bytes_retransmit=9 bytes_invalid=0 send_seq=475 receive_seq=475 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994099 adj=47994007  toolhead: temp=37.5 raspberry_pi: temp=37.5 mcu_temp: temp=38.1 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.44 cputime=37.471 memavail=1561336 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-23.8 pwm=1.000
Stats 351.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797252 bytes_read=183345 bytes_retransmit=9 bytes_invalid=0 send_seq=20549 receive_seq=20549 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001725 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5445 bytes_read=41426 bytes_retransmit=0 bytes_invalid=0 send_seq=599 receive_seq=599 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999876 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3434 bytes_read=51440 bytes_retransmit=9 bytes_invalid=0 send_seq=477 receive_seq=477 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994096 adj=47993934  toolhead: temp=37.1 raspberry_pi: temp=38.0 mcu_temp: temp=38.1 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.44 cputime=37.558 memavail=1560420 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-22.5 pwm=1.000
Stats 352.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797312 bytes_read=183543 bytes_retransmit=9 bytes_invalid=0 send_seq=20552 receive_seq=20552 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001727 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5466 bytes_read=41548 bytes_retransmit=0 bytes_invalid=0 send_seq=601 receive_seq=601 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999903 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3440 bytes_read=51455 bytes_retransmit=9 bytes_invalid=0 send_seq=478 receive_seq=478 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994092 adj=47993803  toolhead: temp=37.0 raspberry_pi: temp=38.0 mcu_temp: temp=38.1 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.44 cputime=37.647 memavail=1560420 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-21.7 pwm=1.000
Stats 353.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797318 bytes_read=183646 bytes_retransmit=9 bytes_invalid=0 send_seq=20553 receive_seq=20553 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001725 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5472 bytes_read=41644 bytes_retransmit=0 bytes_invalid=0 send_seq=602 receive_seq=602 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999894 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3446 bytes_read=51470 bytes_retransmit=9 bytes_invalid=0 send_seq=479 receive_seq=479 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994088 adj=47993689  toolhead: temp=37.1 raspberry_pi: temp=38.0 mcu_temp: temp=38.1 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.44 cputime=37.734 memavail=1560196 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-24.9 pwm=1.000
Stats 354.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797324 bytes_read=183763 bytes_retransmit=9 bytes_invalid=0 send_seq=20554 receive_seq=20554 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001726 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5478 bytes_read=41753 bytes_retransmit=0 bytes_invalid=0 send_seq=603 receive_seq=603 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999896 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3452 bytes_read=51498 bytes_retransmit=9 bytes_invalid=0 send_seq=480 receive_seq=480 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994081 adj=47993621  toolhead: temp=37.3 raspberry_pi: temp=37.5 mcu_temp: temp=38.0 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.44 cputime=37.819 memavail=1559748 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-24.9 pwm=1.000
Stats 355.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797384 bytes_read=183961 bytes_retransmit=9 bytes_invalid=0 send_seq=20557 receive_seq=20557 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001723 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5484 bytes_read=41863 bytes_retransmit=0 bytes_invalid=0 send_seq=604 receive_seq=604 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999888 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3458 bytes_read=51513 bytes_retransmit=9 bytes_invalid=0 send_seq=481 receive_seq=481 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994078 adj=47993516  toolhead: temp=37.0 raspberry_pi: temp=38.0 mcu_temp: temp=38.0 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.41 cputime=37.908 memavail=1559748 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-24.8 pwm=1.000
Stats 356.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797444 bytes_read=184130 bytes_retransmit=9 bytes_invalid=0 send_seq=20560 receive_seq=20560 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001719 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5505 bytes_read=41985 bytes_retransmit=0 bytes_invalid=0 send_seq=606 receive_seq=606 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999886 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3464 bytes_read=51529 bytes_retransmit=9 bytes_invalid=0 send_seq=482 receive_seq=482 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994068 adj=47993508  toolhead: temp=37.0 raspberry_pi: temp=38.0 mcu_temp: temp=38.0 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.41 cputime=37.994 memavail=1558852 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-25.2 pwm=1.000
Stats 357.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797504 bytes_read=184299 bytes_retransmit=9 bytes_invalid=0 send_seq=20563 receive_seq=20563 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001717 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5511 bytes_read=42094 bytes_retransmit=0 bytes_invalid=0 send_seq=607 receive_seq=607 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999885 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3470 bytes_read=51545 bytes_retransmit=9 bytes_invalid=0 send_seq=483 receive_seq=483 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994058 adj=47993401  toolhead: temp=37.4 raspberry_pi: temp=37.5 mcu_temp: temp=37.9 heater_bed: target=0 temp=44.5 pwm=0.000 sysload=0.41 cputime=38.079 memavail=1564212 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-23.1 pwm=1.000
Stats 358.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797613 bytes_read=184563 bytes_retransmit=9 bytes_invalid=0 send_seq=20568 receive_seq=20568 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001716 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5517 bytes_read=42204 bytes_retransmit=0 bytes_invalid=0 send_seq=608 receive_seq=608 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999890 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3476 bytes_read=51561 bytes_retransmit=9 bytes_invalid=0 send_seq=484 receive_seq=484 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994046 adj=47993293  toolhead: temp=37.1 raspberry_pi: temp=37.0 mcu_temp: temp=37.9 heater_bed: target=0 temp=44.4 pwm=0.000 sysload=0.41 cputime=38.167 memavail=1563512 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-26.2 pwm=1.000
Stats 359.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797668 bytes_read=184746 bytes_retransmit=9 bytes_invalid=0 send_seq=20571 receive_seq=20571 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001716 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5523 bytes_read=42300 bytes_retransmit=0 bytes_invalid=0 send_seq=609 receive_seq=609 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000004 adj=11999913 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3482 bytes_read=51590 bytes_retransmit=9 bytes_invalid=0 send_seq=485 receive_seq=485 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994035 adj=47993197  toolhead: temp=37.3 raspberry_pi: temp=38.5 mcu_temp: temp=37.9 heater_bed: target=0 temp=44.4 pwm=0.000 sysload=0.41 cputime=38.258 memavail=1562616 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-26.7 pwm=1.000
Stats 360.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797674 bytes_read=184849 bytes_retransmit=9 bytes_invalid=0 send_seq=20572 receive_seq=20572 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001711 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5544 bytes_read=42421 bytes_retransmit=0 bytes_invalid=0 send_seq=611 receive_seq=611 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999901 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3488 bytes_read=51606 bytes_retransmit=9 bytes_invalid=0 send_seq=486 receive_seq=486 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994024 adj=47993117  toolhead: temp=36.9 raspberry_pi: temp=38.5 mcu_temp: temp=37.8 heater_bed: target=0 temp=44.4 pwm=0.000 sysload=0.37 cputime=38.343 memavail=1561440 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-22.8 pwm=1.000
Stats 361.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797680 bytes_read=184981 bytes_retransmit=9 bytes_invalid=0 send_seq=20573 receive_seq=20573 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001711 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5550 bytes_read=42545 bytes_retransmit=0 bytes_invalid=0 send_seq=612 receive_seq=612 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999898 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3494 bytes_read=51622 bytes_retransmit=9 bytes_invalid=0 send_seq=487 receive_seq=487 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994015 adj=47993083  toolhead: temp=37.1 raspberry_pi: temp=37.5 mcu_temp: temp=37.9 heater_bed: target=0 temp=44.4 pwm=0.000 sysload=0.37 cputime=38.432 memavail=1563468 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-26.1 pwm=1.000
Stats 362.4: gcodein=0  mcu: mcu_awake=0.001 mcu_task_avg=0.000005 mcu_task_stddev=0.000005 bytes_write=797740 bytes_read=185150 bytes_retransmit=9 bytes_invalid=0 send_seq=20576 receive_seq=20576 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=180001708 sb2040: mcu_awake=0.003 mcu_task_avg=0.000013 mcu_task_stddev=0.000021 bytes_write=5556 bytes_read=42641 bytes_retransmit=0 bytes_invalid=0 send_seq=613 receive_seq=613 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=12000003 adj=11999895 mmu: mcu_awake=0.001 mcu_task_avg=0.000009 mcu_task_stddev=0.000009 bytes_write=3500 bytes_read=51638 bytes_retransmit=9 bytes_invalid=0 send_seq=488 receive_seq=488 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=47994002 adj=47993053  toolhead: temp=37.2 raspberry_pi: temp=38.0 mcu_temp: temp=37.8 heater_bed: target=0 temp=44.4 pwm=0.000 sysload=0.37 cputime=38.518 memavail=1563092 print_time=151.745 buffer_time=0.000 print_stall=0 extruder: target=220 temp=-28.4 pwm=1.000
Attempting MCU 'mcu' reset command
Attempting MCU 'sb2040' reset command
Attempting MCU 'mmu' reset command
webhooks client 4095262256: Disconnected
- DEBUG: Klipper disconnected! MMU Shutdown
