Hello,
one of recent updates (within last 2-3 months) casued some of my files unprintable because of Polish language special characters inside the files:
Because of the CAD model containing “Ł” in its name, there it is also in the comment section before 1st layer.
At this point, before this line, the printer stops. Klipper shuts down due to unhandled exception during run.
Some of my gcodes are actually 1-2 years old. To fix the issue I have to edit files and replace all Polish characters to English characters, For instance Ł->L.
Any chance to insert support of polish special characters as it used to do several months ago? (or maybe it was ignoring comments before?)
There are nine letters created using diacritical signs (ą, ć, ę, ł, ń, ó, ś, ź, ż).
Additional feature would be to allow special characters in filename too (this isn’t working since long ago)
Sample gcode below.
1st block is macro for start print.
Below starts actual print.
;TYPE:Custom
M109 S0
M190 S0
START_PRINT EXTRUDER_TEMP=260 BED_TEMP=100
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
; Filament gcode
M107
;LAYER_CHANGE
;Z:0.2
;HEIGHT:0.2
;BEFORE_LAYER_CHANGE
G92 E0
;0.2
G10 ; retract
G1 Z.2 F6000
;AFTER_LAYER_CHANGE
;0.2
; printing object Adapter Gorenje i Łucznik i Grundig.STL id:0 copy 0
G1 X97.787 Y108.036
G11 ; unretract
M204 S500
;TYPE:External perimeter
;WIDTH:0.419999
G1 F1200
G1 X98.044 Y107.141 E.02861
