Bug with Cyrillic in gcode comments
Printer Model: voron switchwire
MCU / Printerboard: skr3ez
If the file code or comments contain Cyrillic, this creates a problem. For example, the file contains a material with a Cyrillic name; at 100% printing, because of this comment, the end_print macro does not work because the firmware goes into error
; filament_settings_id = "FDPlast TPU Веном"
if I fix name to english — all will work fine
; filament_settings_id = "FDPlast TPU venom"
Unhandled exception during run
  File "/home/pi/klipper/klippy/klippy.py", line 217, in run
    self.reactor.run()
  File "/home/pi/klipper/klippy/reactor.py", line 292, in run
    g_next.switch()
  File "/home/pi/klipper/klippy/reactor.py", line 340, in _dispatch_loop
    timeout = self._check_timers(eventtime, busy)
  File "/home/pi/klipper/klippy/reactor.py", line 158, in _check_timers
    t.waketime = waketime = t.callback(eventtime)
  File "/home/pi/klipper/klippy/extras/virtual_sdcard.py", line 261, in work_handler
    next_file_position = self.file_position + len(line.encode()) + 1
UnicodeEncodeError: 'ascii' codec can't encode characters in position 38-42: ordinal not in range(128)
Transition to shutdown state: Unhandled exception during run
klippy.log (855.3 KB)
prokladka_0.2mm_FLEX_Switchwire.gcode (471.2 KB)
It’s a known problem Internal error on command:"SDCARD_PRINT_FILE" · Issue #4794 · Klipper3d/klipper · GitHub
Yes, I saw this issue, but before updating the version to 0.12, comments in Cyrillic did not cause such problems.
; generated by PrusaSlicer 2.5.2+MacOS-x64 on 2023-06-16 at 07:46:08 UTC
; filament_settings_id = "FDPlast PETG Черный ворон"
UPD:
I have two printers
skr 3 ez
  • fluidd v1.28.1
  • klipper v0.12.0-114-ga77d0790
  • Klipper-Adaptive-Meshing-Purging v1.1.2-10-g093c57bf
  • moonraker v0.8.0-318-g9813011d
  • mcu v0.12.0-113-g28f06a10
and
manta m8p 1.1
  • fluidd v1.28.1
  • mainsail v2.10.0
  • mcu v0.12.0-85-gd785b396
with second printer, I don’t have any problems with Cyrillic in comments
But on second printer I have configuration
[virtual_sdcard]
path: ~/printer_data/gcodes
on_error_gcode: CANCEL_PRINT
UPD2
I turned off the setting on the second printer. I added a comment in Cyrillic as the second line in gcode and the second printer ignored it. The first one with the same comment went into error
Just don’t use gcode with non-ascii characters and you’ll be fine :wink:
Python: ‘2.7.18 (default, Jul 14 2021, 08:11:37) \n[GCC 10.2.1 20210110]’
Python 2 has no upstream support since 2020 (Sunsetting Python 2 | Python.org), and among other deficiencies does not handle unicode characters the same way as Python 3. I would recommend using a more recent version of Python for your Klipper install.
this is not a solution
I’ll check it, thanks
After upgrade python — problem gone.
