Print error at start
Printer Model: Ratrig Vcore 31
MCU / Printerboard: Octopus Pro + Ebb42
yesterday worked fine… but today i have send a file to print and when the work and…
When the print job was going to start, I received this message through the console and the printer restarted… I tried another slicer, and the same message…
I have NOT updated the printer, I just stopped it yesterday and turned it on today, or so I think
Internal error on command:"SDCARD_PRINT_FILE"
Printer is shutdown
and this message in console
{'message': "'ascii' codec can't decode byte 0xc3 in position 48: ordinal not in range(128)", 'error': 'WebRequestError'}
klippy.log (1.4 MB)
What can be?
EDIT: I add more information… it has to be from the Slicer… because I have sent a piece to be printed that printed well, and works correctly
I think I have discovered the problem, it is related to the name of the gcode…
For my organization I name them with a template:
SLICER_MATERIAL-Name
Until now it had worked without a problem… but since this morning it hasn’t… I have had to rename the files to a simpler name…
and for now it works…
but… why before yes, and now no?
  • You have named your gcode file containing some non-ascii characters, like “código g extraño”
  • You are using Python 2, which cannot deal with such characters
Solution:
  • Do not use such characters
  • Upgrade to Python 3
