Help virtual_sdcard dispatch
Printer Model: Moded ender 3 v2
MCU / Printerboard: octopus v1.1
klippy.log (23.5 KB)
i am setting up my new printer board with mainsail
i am really far but i got to a wall again
i want to start a print and it auto stops after it try to heating the bed then if i try to resume it just stops again if i try to cancel the print it wont let me and i am not getting a viseble error on the webserver or screen
the error it gives in the klippy.log is
File “/home/pi/klipper/klippy/extras/virtual_sdcard.py”, line 264, in work_handler
self.gcode.run_script(line)
File “/home/pi/klipper/klippy/gcode.py”, line 216, in run_script
self._process_commands(script.split(‘\n’), need_ack=False)
File “/home/pi/klipper/klippy/gcode.py”, line 200, in _process_commands
self._respond_error(str(e))
UnicodeEncodeError: ‘ascii’ codec can’t encode character u’\ufeff’ in position 20: ordinal not in range(128)
Exiting SD card print (position 314)
if you know how to fix this pleas help me
thx for the help already
This looks like there are “strange” characters either in your gcode filename or within the gcode itself. Please post the gcode file you wanted to print
this is the gcode
CE3_M5_Nut.txt (146.3 KB)
i canged the file extention other wise i cant upload it
The red marked characters are usually invisible unless you set an editor to ANSI encoding. Correct these and it should work.
